The display of your T.V. may have burnt out and may need to be completely replaced. My other answers would have been to replace the items you stated you replaced.
Bummer. Was worried about that. Thanks.
Abctay.com is a samsung tv parts online store ,has many kinds of samsung tv parts include SAMSUNG BN44-00513A P60FW_CPN BN4400513A POWER SUPPLY FOR PN60E6500EFXZA
https://www.abctay.com/samsung-bn4400513a-p60fwcpn-bn4400513a-power-supply-for-pn60e6500efxza-p-1490.html
SOURCE: After replacing y-sustain board have nothing but vertical lines on screen
well..sounds like the main control board to me..these things tend to fail as a group, by the way...
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: acer aspire 3690 the right half of my screen is black/white/lines
It sounds to me like your screen has gone and needs to be replaced
SOURCE: have zenith plasma tv
There are a couple of different things that could cause this problem,
the first is the power supply, and the second the main board. Also
either sustain or scan driver board can cause this problem. To know
exactly what board is the cause, you need to have electronic repair
experience, and test equipment. If you have this let me know and I will
assist you in the troubleshooting of this tv. Otherwise you will need a
repairman at this point. You can expect a bill of anywhere between
$200-$500, this is a good average, however it could be more or less.
I
am sorry I don't have a quick fix or easy answer for you on this one,
please let me know if you have the skills and tools and I will be happy
to assist you. Also please let me know if there is anything else I can
do for you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
