Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Shelves not saying in grommets. This happens will
Shelves not saying in grommets. This happens with little weight. Freezer works great, but shelves keep falling.
I have exactly the same problem and it is mostly because of the cheap plastic support brackets. I'd like someone to to offer a cheap way to "rig" it so it will support the weight of the shelves when full. Glad tyo know I am not the only one.
Posted on Sep 26, 2009
How do I reinforce freezer shelves?
The freezer should not be totally be full otherwise the cooling system will not succeed to reach its design temperature. If the shelve is still bending, get a piece of maple about 1x2" and attach it to the shelve at each end with a piece of nylon rope.
May 01, 2014 | General Electric FUF21SVRWW GE 20.6 Cu....
I have a Magic chef upright freezer i can hear the compresser running but it will not freeze meat
Has this happened suddenly? Look at the shelves to see if there is a frost line. If the shelves that also carry the Freon appear to have a frost line your freezer may have a Freon leak. If there is a Freon leak it will be better to begin looking for a replacement freezer. Let me know what you see, Thanks Sea Breeze
Nov 29, 2012 | Magic Chef 11.8 cu. ft. / 334 liter...
My freezer didn't have ice on the shelves until
Most likely cause is a door being left ajar or gaskets not seating. If the ice looks like snow, that is your issue.
Jun 25, 2011 | Kenmore Freezer 20.6 cu. ft. Upright...
Quit staying cold
TV is no problem and will have no effect...
This tip will help you see what has happened with your unit..
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Apr 22, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Lower shelves keep falling down out of wall supports
replace gromments and reduce the weight that you put inside the shelf/basket.
Apr 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I HAVE AN UPRIGHT FREEZER THAT IS DEVELOPING FROST ON ALL THE SHELVES, I DEFROSTED IT TODAY AND RIGHT AWAY THE SHELVES DEVELOPED FROST AGAIN. THIS HAS NEVER HAPPENED BEFORE, IT WOULD GET FROST ON THE...
Sounds like an air leak. Check the door gasket. If that is sealing well all the way around, try putting a peice of foil duct tape over the two small vents in the bottom of the door.
Sep 05, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
The top shelf in my upright freezer ices up badly; but the rest of the freezer is great - no ice! What causes this and is there something I can put on that shelf to keep the ice from building up.
If this is the type of freezer where the shelves are the evaporator coils, the coolant goes through the shelves(tubing) and the formation of frost is normal and has to be manually defrosted.All the shelves should be as cold asd the top one. The fact that just one has any frost may indicate that it is low on freon. If this is the case you should notice that the freezer doesn't get cold enought.
Sep 02, 2009 | Freezers
Upright freezer.Two shelves freeze up. One doesn't. Why and is this a problem
look to see if the shelves are in fact not shelves but evaporator coils . if the shelf is connected to small tubing, then that tubing flows freon that freezes the shelf. if its clearly not connect to any tubing or piping then its just a shelf and gets residual cold from evaporator shelves. if it is connected to tubing like the others and not getting cold then you have whats called a restriction. . particles have plugged the tubing and no freon is feeding the shelf. if that is happening then consider having a pro recover the gas , unplug the tubing , replace the drier and recharge it. if its an older unit and you are getting by then maybe not worth the expense.
Nov 01, 2008 | Kenmore Freezers
Not all shelves freezing Alarm on
If this is not a frost free unit. I say replace it. I don't believe in recharging a deep freeze. You can never really trust them again. The food inside is worth more than the freezer. If this is a frost free unit, See if the fan inside is working. This can also be a defrost system proplem such as a timer and well worth fixing.
Jun 23, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
188 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
