Question about Ryobi Garden
Need carb settings on both screws on Ryobi C430
  • 41 Answers
Start with both screws about 1 and a half turns out from fully screwed in. The high screw will set your fuel for wide open. Back it out until you hear the motor run almost wild then screw it back in about a half a turn. The low screw is a little trickier. When you can quickly go to full throttle from idle its about right.
Posted on Aug 02, 2009
How do I adj carb on ryobi bp42 that is too lean
some carbs have a small screw located in the throttle shaft at the lever
there may be a small plastic block that has to be removed first and then a small screw driver to adjust the screw
probably better to get a repair kit or new carby as that setting very seldom changes
Oct 24, 2016 | Ryobi Garden
How do i set the carb on a ryobi
I haven't heard of Ryobi using a carb different to most similar machines which use a small diaphragm-type carb which uses suction impulses from the 2-stroke engine crankcase to lift fuel from the fuel tank into the carb. There is generally one screw which is a throttle stop and two screws which are fuel volume screws; one with a greater influence at low speed and idle and one with greater influence at high speed. The low speed screw does have some influence at high speed and the high speed screw does have some influence over low speed fuel mixture.
The basic settings of the screws should not be lost and if stripping and cleaning the carb each screw should before removing be carefully turned in, counting the turns, until it bottoms so after cleaning it can be returned to its former position.
The amount of adjustment from the position the manufacturer set each screw to would typically be in the order of plus or minus one-eighth of a turn and if adjustment of more than about a quarter-turn is needed it could indicate the carb needs a thorough clean.
Making an adjustment of one screw means adjustment of the other is almost inevitable. The basic requirement is for the machine to work under load efficiently at high speed and it is usually desirable the machine will be capable of idling. Obtaining both is rather a balancing act and will need some patience and time making minor adjustments of each screw and in practice some compromises must be made and if hard work at speed has been achieved it usually doesn't pay to try too hard to achieve a smooth idle.
Feb 25, 2015 | Ryobi Garden
My ryobi c430 4 stroke trimmer dies after mid throttle. What is the procedure for adjusting the air/fuel mix?
there's usually just a screw you have to sort of play around with until you find the right combination
Jul 15, 2012 | Ryobi Garden
Ryobia trimmer won't idle.
most likely to rich low speed screw try turning it in 1/8 turn it should pick up rpm then back off the idle a scoche
Apr 27, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I adjust the throttle cable on a C430 String Trimmer? When I depress the throttle cable, the linkage on the carburetor only moves about 1/16 inch and will barely turn the cutting head.
The throttle cables aren't adjustable. Make sure the other end is on the trigger correctly and that it is routed through the handle and the engine cover correctly. Also, make sure the throttle shaft and throttle plate (inside carb) are free and easy in their movement with the throttle cable off. The engine idle speed adjusting screw may be in too far also. Back it all the way out and then back in with the throttle closed Once the speed screw touches the throttle lever (what you hook cable into) on the shaft, give it about 2 turns in. This is about all you can do. If the cable is stretched badly (rare), it would need to be replaced.
Oct 26, 2010 | Ryobi Garden
I have a brand new Ryobi C430 trimmer that will not start or even attempt to start. Have followed all instructions. Bought from Home Depot. Need help. Ed
for any engine to start and run it must have correct mixture fron carb,,a spark at plug at the right timing,=so many degrees before tdc, which depends on what the engine is,, adiquitt compression to promote combustion, diesels use ultra high compression ratio for the diesel which is injected at aperciffic timing and the diesel detonates due to high compression which is why some knock badly
Jun 21, 2010 | Garden
What are the carb settings on a Ryobi 765R???
It should be 1 1/4 turns on the screw with the letter L and 3/4 turns on the screw with the letter H. Off course, both screws need to be lightly seated before backing them out. Good luck
Oct 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Brand new C430 leaking gas or oil over the gas recepticle. Put extender for limb cutting and it keeps dying. How do I fix this?
I have the same problem. It would appear to be coming from the tube right outside the carb intake. I am not sure there is a solution for this. I am going to take mine back and swap it out. After tweaking the needles and getting it running perfectly, I really like it other than the goo sludging all over the tank.
Jun 30, 2009 | Ryobi Garden
Ryobi pcn3335 wont start at all. Not a kick???????????
Hmmm could be a clogged muffler,fuel line, the carb might need to be cleaned or rebuilt or dirty fuel filter or if u have on the saw thers a low and high idle screw setting, usally on the side of the carb that might need to be adjusted.
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
1,539 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
