Question about Honda Pressure Washer PSI 3000
Pump with upgraded pump only getting half power
Excell power washer v2500bought a upgrade pump, only get half the pressure now. tried adjustment screw, engine stalls hard to pull start also, unless water off first.no leaks found, any idea.
  • 90 Answers
If you bought a new pump make sure its the correct type
then check for a unloader the adjustment part like a handle or an Allen screw on the head of the pump
dismantle grease up and replace
Posted on Aug 02, 2009
How did the upgrade pump for Excel VR2500 seize during first use?
This happens when the pump is installed. When you slide the pump up the shaft and the key slides up the shaft to the curved groove in the engine shaft. When this happens it forces the key to push to far in to the pump hollow shaft and cracks and breaks it
May 27, 2014 | Annovi Reverberi RMW2.5G25D
Excell pressure washer
What is your model #
http://www.ppe-pressure-washer-parts.com/excell-devilbiss-pressure-washer-replacement-pump-parts
Nov 03, 2013 | Homelite For Excell - Pressure Washer Pump...
I have a ic2 pump on my pressure washer, the diagrams have failed. My question is I need the parts to repair it, or how to purchase a replacement.
You can purchase a complete unit from Grainger for about $210.00. Their part number is 6UZP8. And in most cases they are located locally, so you can pick it up and be back in business quick. The pump is actually manufactured by Excell Power, so my thought would be replace the pump and then try to find a rebuild kit for the bad pump and try to rebuild it as a backup. Hope this helps.
http://www.grainger.com/Grainger/EXCELL-Assembly-Pump-6UZP8
Jun 13, 2011 | Honda Garden
What kind of oil do you put into a Excell pressure (exh2425) washer pump? Do you use the same as engine oil (30 w)?
Pressure washer oil
I took this picture of my power washer so it's easy to explain the oil.
The oil is different for engine and pump.
The pump oil is 20 or 30 weight non-detergent. SAE20 or SAE30 motor oil. The level of the oil comes up about half way. There is a plastic viewport on side of pump ... oil comes up half way on viewport.
The engine oil is 10W30 motor oil. It comes up about half way or a bit more on dipstick.
To remove oil from pressure washer, do not turn engine on it's side or turn engine upside down or motor oil will run into the carburetor. You might wonder how I know that. Afterward, the carburetor needs to be cleaned out.
To remove oil, you can tip engine to the side but not so much that oil runs up into top part ... to remove the rest of the oil, you can use a plastic hose
Oct 19, 2010 | Garden
Excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Jul 25, 2010 | Honda Garden
Excell vr2500 pressure washer ,no pressure, took off high pressure hose at bottom of washer , get water flow, but flow does not change when engine is running full throttle
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Jul 29, 2009 | Garden
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
No pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
May 22, 2009 | Karcher 2500 PSI Pressure Washer
Honda Pressure Washer PSI 3000 Logo
228 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
