Customer care support SERVICE number+1--833'''272''''0777,,,,,,,,,,,call them
try looking on the HONEYWELL site (yes honeywell tooke over ADEMCO or ask a local alarm installation business they could find one for you
SOURCE: Westinghouse Security System
Download the manual. I can't remember if it is in the User's Manual or the Programming Manual but a sequence to reset the security code is detailed in one of them. Also, it soulds like the telephone line was wired through the system for full seizure. To defeat this, you will need to take it out of the phone lines at the outside telco box. How it is wired is that the alarm panel intercepts the telephone line first and then feeds the circuit back out to the main junction where the telco comes into the house.
SOURCE: need to change access code, but need ID. Is it on the main unit
Normally the default codes are either 4321,or 1234.
If those don't work you should try a reset by. first unplugging the red wire behind the system and unplugging the ac adapter. Then you press at the same time the "cancel button" "clock set button" and the "minute plus button" while plugging it in. After that the code should be either 4321, or 1234.
SOURCE: my nokia piece is 5130 Xpress music..i forgot my security code
you cannot reset your password without knowing the previous one. my suggestion is to go to any mobile servicing centre to reinstall ur phones software. this will reset ur password to 12345. software reinstallation is the only option, it costs only Rs 200. if u r within the warranty limit. go to nokia service centre for free.
SOURCE: HOW TO CHANGE FLOOR PLAN ON THE ALOHA POS SYSTEM?
Please tell me if you found the solution, I am trying to do the same thing.
SOURCE: We just moved into a
Cheers
Hi JC W, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
is it a monitored system.
the monitoring company may be able to help you with the setup of the alarm
