Question about Jenn-Air JCB2282H Side by Side Refrigerator
Ice covers the coils in the freezer and then the freezer and refrigerator quit working. A refrig repairman came out and told us to take the cover off of the coils and pour hot water on them to get rid of the ice. We are now having to do that every month, and still the ice covers the outside of the cover. This can not be right.
    Problem Solver:
  • 8 Answers
Turn the temperature inside the fridge and freezer up and it will keep the coils from freezing. the same thing happens in an a/c
Posted on Aug 02, 2009
Why do the freezer coils on my Whirlpool stainless steel model GB2SHDXTSOO ice up?
I posted the problem with my refrigerator that started this thread. I had a repairman out to fix the refrigerator. He replaced the defrost thermostat. About a month later the coils iced up again. I called the repairman back. He said he wasn't sure what the problem was, but he would do some research and get back to me. Two weeks later I hadn't heard from him and he wouldn't return my calls. I finally called another repairman and he came out today. He said the Captain Board is bad. It has a relay sticking. He turned the refrigerator and freezer off, but the refrigerator still kept making noises. He said one of the noises was the damper valve opening and closing, but it shouldn't be because he had turned the refrigerator and freezer off. He listened little longer and asked me if I could hear the humming sound. He said that was the compressor, which shouldn't be making any sounds because everything was shut off. He said the Captain Board costs about $220. Does any of this sound logical
Mar 14, 2013 | Whirlpool GB2SHDXTS Stainless Steel
Freezer keeps frezzing with ice and the refrigerator is not keeping cool
I'm not a refridgerator repairman but when coils get covered with ice it is usally because the refridgerant (freon) is low. You will need a liscened repairman to fix it. If you try to do it yourself, you will be calling a repairman anyway and it will cost way more to fix it then to have repaired.
Nov 20, 2012 | Kenmore Refrigerators
The ice maker in my Whirlpool Gold refrigerator has stopped making ice. There is ice in the tray, but it won't empty itself.
If the " tray " you are refering to , is the ice maker mold , then clean the coils in the front , under the refrig ( condensor coils ) . Also check the fan behind the refrig , to make sure it is working . An ice maker has to be 5 degrees to cycle . Bothe the coils and the fan , have to be checked to be sure the freezer is at the correct temp for the ice maker to opperate properly . If both are ok , then replace the ice maker .
Sep 23, 2010 | Whirlpool Refrigerators
Ice melts, then refreezes. Rubber Is HOT
Pull the refrig out , and remove the back panel . Is the fan that cools the compressor working ? Is the coil roll clean ? If the fan is not working , then the problem is probably the main control board . Behind the 8"X10" panel , above the compressor area . Remove the cover , and look for a burnt resistor , just to be safe . If this fan does not work , then the coils and the refrigerant line running between the doors , will get very hot .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer works but my refrigerator does not. What the problem?
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Dometic Refrigerators
Freezer compartment has frost buildup
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Refrigerator isn't very cold- drinks are just slightly chilled
Usually caused by failure of defrost system, Air ports from freezer to fridge blocked by ice
Aug 23, 2009 | Whirlpool Refrigerators
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Dec 16, 2007 | Refrigerators
Jenn-Air JCB2282H Side by Side Refrigerator Logo
178 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
