eBay sale ended but photo appears to show a manual. Use Contact Seller menu to see if a copy of the manual can be provided or sold to you seperately or jointly with the level. https://www.ebay.co.uk/itm/362303471303?...eBay sale ended but photo appears to show a manual. Use Contact Seller menu to see if a copy of the manual can be provided or sold to you seperately or jointly with the level.
https://www.ebay.co.uk/itm/362303471303?ViewItem=&item=362303471303
You can't post conmments that contain an email address.
Set up the laser level on a flat surface or tripod and turn it on.
Place a target or receiver on a wall or surface where you want to project the laser beam.
Adjust the receiver to the same height as the laser level.
Align the laser level with the target or receiver.
Rotate the laser level 180 degrees and align it with the target or receiver again.
Check the readings on the receiver. The difference between the two readings should be less than or equal to the accuracy specification for the laser level.
If the readings are not within the specified accuracy, adjust the laser level until they are. Use the adjustment screws on the laser level to fine-tune the alignment.
Repeat the calibration process if necessary.
Note: Before calibrating your laser level, make sure it is clean and free from any debris or damage that may affect its accuracy. Additionally, consult the user manual for specific instructions and safety guidelines.
There are detailed instructions in your users manual on how to check and adjust your Topcon laser. You'll need a tripod, 2 vertical surfaces about 50 meters apart and your laser receiver. It's done by marking positions of the beams, on the different surfaces and then adjusting your laser position to the center of the different positions.
The procedure is different for different models, but i have attached some pictures from the manual for the RL-VH4 series.
Where the button is to push laser on & off, there is a metal ring around it. Just unscrew this ring & the batteries will come out. Replace batteries, & rescrew the ring in place.
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Tripod must be level, scope must be in the home position. There is a drive training session described in the manual which you MUST do. Time, Date, and SITE, must all be correct.
