Question about Toshiba 52HM95 52" HDTV Projection Television
Toshiba 52HM95 52 in. tries to turn on. the light by the power buttom blinks then unit turns off does that for a few times
  • 556 Answers
Check the lamp.
Posted on Aug 14, 2009
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Power up problem
it has nothing to do with the ram, it is the issue of the adapter or battery for toshiba laptop, if the output volatge form the adapter is not steady, the light will get yellow and blink,try it on another toshiba laptop. if it is normal, u should test the toshiba laptop battery by the multimeter, connect the electroprobes wiht the anode and cathode, if the pointer does not fixed in a short time ,the battery is the issue. change it for a new one.
Jun 27, 2008 | Toshiba Satellite 1410-S173 Notebook
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Toshiba TP55H60 power down after start up
Try the following
1-unplug tv
2-remove bottom cover on tv
3-tap the power supply frame a few times (where the power cord enters the tv)
I had the blinking red light on my tv. I tried other solutions like removing the red wire a few times etc. Tapping the power supply frame solve the problem.
Aug 11, 2007 | Toshiba TP55H60 55" Rear Projection...
Bad lamp?
If you have the owners manual look on page 64 and see what it says there about the light lighting up in the front of the unit. if you do not have the owners manual, you can get one for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2004/52-62HMX84_E_R1_093004.pdf
Jun 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Blinking power light
Our 61H71 just did the same thing! I have found on another site where a fuse on the Convergence board was replaced as a fix for this issue...however, fuses are usually symptoms not causes...it is very difficult to find availabe information on this issue...it may be time to call a professional...Good Luck!
Nov 18, 2006 | Toshiba 61HX70 61" Rear Projection...
Toshiba 52HM95 52" HDTV Projection Television Logo
346 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
