Question about HP Pavilion tx1000z Notebook
My hp pavilion tx 1000 fan is running high as soon as i power on. my wireless card stopped working last year but HP fixed it now the fan won't stop running.
  • 748 Answers
Hello
The fan is probably going bad. Get it replaced before the fan causes other problems.
Posted on Aug 02, 2009
Wireless stopped working on Hp Pavillion
Try installing the latest wireless card driver.
You can download the wireless and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Mar 17, 2012 | HP Pavilion dv6105us Notebook
Hi, i have an hp pavilion ze2000 with the built in wireless adaptor. its been sitting in a box for 4 years because the ac power stem was 'broken'. i took the laptop apart and fixed that and the...
well it can only be 2 things,
the card is bad, and the do go bad.
or the drivers are wrong
why not find the true name if the card, on the card
the using HP.COm use the correct driver for that card.
HP can uses 2 or 3 different cards, some have blutooth.
its not just one offered.
this LP is old, its seems its got XP on it,? the virus magnet.
why not get a newer LP say year 2010 and newer with W7 or newer
so you get both HP and MS support.
ze2000 tells us nothing much sorry
that is not a product number.
this info here is the only why to get the correct drivers
there IS NO OTHER WAY,
go to hp.com they ask you then same thing,
do so.,
one trick if say there are 3 wifi drivers, for say XP and only on your exact machine at HP.com
then run all 3 drivers, 2 will fail, and 1 will not.
this is an HP secret, saves pulling card out and reading its words.
but after talking to HP
its no longer supported, its over 12 years old,
its listed on RETIRED page, (MEANS END OF LIFE)
http://support.hp.com/us-en/retired-products
Mar 17, 2017 | HP Computers & Internet
I have hp pavilion TX 1000 my Wireless stop working how can i fix it?
Take out the network card. Start your PC.Shut down.Put back it , start up. Post back
Oct 20, 2010 | HP Computers & Internet
Red wireless light wont turn green, no wireless connection found, stays red all the time dv7-1020 pavillion notebook, no wireless switch that i can see just the light in upper right, stays red, all the...
I have a tx 1000 with pretty much the same problem. Short answer is : if you are still under warrenty demand that hp replace the entire unit (basically they put together a lousy design, it doesn't allow for adequate ventilation and consequently the motherboard cooks itself and other components attached to it. swapping out parts will only briefly "fix" the problem.
the simplest cheep fix is to get a usb wifi adapter and connect with that (untell eventually the machine will cease to boot, lights will come on fans will run but nothing else will happen)
and you like me will not only be the proud owner of a really cool looking paperweight but also will never consider buying anything from HP again.
Oct 10, 2010 | HP Pavilion dv7-1020us Notebook
HP Pavilion dv9700 laptop, Wireless stops working at random.
HP's normally use the Atheros wifi card which recently has had many problems such as what you describe here. Try a different wifi card to see if this solves the problem. If you don't have a wifi card take it to a local repair shop to see if they have one they can try for you.
Sep 23, 2009 | HP Computers & Internet
I have a HP Pavillion TX 1000. Did everyone heard
It is highly improbable that heat from the CPU can crack a LCD screen. Even if the fan was faulty the CPU would have shutdown (thermal overload) before it would affect the LCD screen. If you apply pressure to the face of the LCD screen or twist the screen or impact the screen with a hard object, any of these will cause the LCD screen to crack.
Jun 11, 2009 | HP Pavilion tx1000z Notebook
HP Pavilion dv9205us.....my wireless stops working after I shut my computer down. I reinstall the drivers and it work for a while, then it justs stops.
You can try reseating your wireless card...it's 2 screws after you remove the Memory cover on bottom. HP has issue on motherboards that can cause this and has extended warranty on this model and others to 2 years.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&product=1842189&docname=c01087277#c01087277_identify
May 04, 2009 | HP Pavilion dv9205us Notebook
How to fix the touch screen for a hp pavillion tx 2000
Please run system restore from your control panel to an earlier date.
Apr 24, 2009 | HP Pavilion TX2000Z Notebook
HP Pavilion tx 1000 tablet PC. Wireless Internet connection to my comcast internet has ceased working. It worked until the power cord went out and I bought a new one, came home and I can now not connect in...
Guru j/k and I spent several hours last night on this problem. We Instant Messaged on Skype and finally figured out that an old expired copy of Norton Security Suite was the cause of the problem, once removed, no mor problem. Guru is the man. He was pleasant, persistent and knowledgable. I highly recommend your service. If the need arrises, I will contact you guys first.
Feb 07, 2009 | HP Computers & Internet
Will not power up
there is a known issue with the GPU on these boards going out. thats why you have the strange rolling on the screen. i have sent some units in to hp to get new motherboards.
send it in, after that i believe you will at least have 90 days on the repair.
call hp and they will send you a box, you should get it back in 7-10 biz days last i checked.
in some cases on the s3000 series they have added an extended 12 mos to original purchase dat or before 12.31.09 whatever is first.
get it done now before its too late
Good Luck!
Ruben
Nov 29, 2008 | HP Pavilion Slimline S7410N Notebook
Computers & Internet Logo
713 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
