Shakeing badly when full with cloths or even empty my washing machine shakes bad.. what can i do. i have the machine level in all directions and still does it
    Problem Solver:
  • 6 Answers
The bolts are lose either tighten the bolts of the drum of tilt it forward slightly
Posted on Aug 02, 2009
I leveled my machine but t jumps badly
my answer it maybe not the answer you want !
watch if the clothes have made a bundle on one side ?
a washing-machine Too full stop the spreading the clothes evenly ,,
but if a front loading ,
the four rubber feet must touch the floor evenly ,
look for the two front rubber feet are level and push hard on the top to level the back legs automatically or adjust them manually !!
Oct 04, 2015 | Bosch Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
The washing machine model is DWD-G20D1 it just stops after about 10 minutes or so and starts beeping. H6 shows up on the display also. The fabric conditioner is not taken from the drawer but the soap...
it is shakeing during the spin if so level it saftey switch shutting it down because of low voltage...low water''' or to much shakeing going on durning spin
Mar 16, 2011 | Washing Machines
During the lest spin cycle ,the drum spins like its out of balance, with bad knock , viberation. even after making sure the load is balanced in the drum. even without a load or water, (empty) it still...
The machine sounds as if it might be unsteady. If it only happens on the spin it is probably slight. Try levelling it at the feet, using a spirit level helps enormously to get it level.
Dec 09, 2010 | Washing Machines
Shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Mar 29, 2009 | Washing Machines
Matag washer Performa shakes badly on spin cycle
Ensure the washer is level by rocking it. If its level should'nt be able to move. You may have a weak floor. to checks this look to see if anything is vibrating around the washer.
Feb 10, 2009 | Maytag PAV2300 Top Load Washer
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washing machine shakes violently
There is the tub that spins on the bearing the " the active tub"(the one the clothes go in obviously) and around that tub is the "stationary tub", between the two are what they call "snubs" these are either rubber wheels, bushings or on cheaper models just a rubber boot that works as a shock absorber if you will, and keeps the movement of the the "active tub" with in its axis. If a wheel is broken, or a bushing/boot is torn or broken then there lies your problem.
I hope this helps.
Aug 06, 2008 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
