Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
When I start my computer my Dell S199WFP Flat Panel Monitor does not go on and stay on. It comes on for about two seconds or and switches off. I have to turn it on about 20-30 before it will stay on. While doing this, the two or three seconds when the screen appears, the image is not fully lite. Once it "takes" the image flutter from light to bright and is okay until I turn it off/on again. Can you help me solve this problem?
  • 748 Answers
Hello
You have capacitors on the monitors power supply that have changed value. Soon they will keep the monitor from turning on at all. Send it to a company like mine or take it to a local repair person.
Posted on Aug 02, 2009
  • real_qayin Oct 21, 2010
    Just reporting that my dell S199WFP lcd is doing the same thing. Dell seems to cheap out when it comes to quality capacitors. Something similar happened at my work where we were having to return 1 out of 10 machines due to faulty capacitors on the motherboards.
  • Kenni
    Kenni Nov 25, 2013
    Is there anything that can be done at home about this problem?
Dell monitor S199WFP....the blue power light stays on....the screen goes black after a few seconds. I've checked the power cord and the cord connecting the monitor and computer. Do I just need to get a new...
What do you mean your screen goes black. It is black to start isn't it? Does it come on at all?
If you meam you are getting a display, but it goes off, you need to check the power settings for your monitor, that are set by your PC. Click start, then control panel, then double click display. Then in the Dispay Properties window, click the Screensaver tab at the top middle.In the lower half of the page which opens, you can find power settings, and the rest is self explanatory. If this is not the answer to your problem, you need to give more detailed information.
One check you can do is to disconnect the signal cable from your monitor, and switch power on, and see what is displayed. You may well need a new monitor, but before running off to buy one, try to borrow one to connect to your pc, and also if possible, try to connect your monitor to another pc, or to a notebook/laptop.
Jun 18, 2010 | Dell S199WFP 19" Monitor
Does this s199wfp monitor have audio
nope but you can get a soundbar for it for realtively cheap.
http://accessories.us.dell.com/sna/products/Video_Conferencing/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=313-6413
that soundbar is designed for the monitor it attaches perfect to the bottom.
Apr 06, 2010 | Dell S199WFP 19" Monitor
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
The monitor comes on and then goes black.
Sounds like your LCD panel lamps are shutting down, this could be either due bad tubes, or more likely lamp driver power supply is faulty.
Jan 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell monitor will come on but will not stay on. stays on 5sec
5 seconds? Hmm, too long for inverter driver turning into protection caused by bad lamps. Also too long for PWM controller in the switching power supply.
Rather looks like overheating of the FETs in the inverter, they are driving HV-transformers. Open the monitor, remove metal lid and observe inverter board. If PCB under and around these FETs is darkened, replace them.
These Dells hard to open. Take the foot off and unscrew plastic cover. Then using flat screwdriver with wide blade separate plastic halves of the case, starting from bottom edge and moving to opposite. It might be sweaty.
Sep 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
I am unable to restore to factory setting. how
http://support.dell.com/support/edocs/monitors/S199wfp/en/UG/setup.htm
The link provides how to operate all your Dell Display functions including the reset to factory defaults
Jun 23, 2009 | Dell S199WFP 19" Monitor
My monitor screen goes black
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
May 16, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
476 people viewed this question
Alun Cox
