Question about Refrigerators
The fridge is not cold ednough what temperature should it be set to?
  • Refrigerators Master
  • 3,307 Answers
Sorry... I only speak Fahrenheit ...
The Freezer needs to be set at ZERO...
for really good HARD ICE CREAM and the REFiGERATOR
is BEST just above FREEZING at 33 degrees...
Most refrigerators have micro adjustments to keep
your produce FRESH, meat thawed and your beverages
delightfully chilled...
Reading the OWNERS manual is always BEST.
Allow 72 Hours for temperatures to stabilize....
http://wikipedia.org/wiki/carnac_the_magnficent
Posted on Jun 12, 2018
SOURCE:
kweaver1
  • 3 Answers
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Posted on Jan 20, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Freezer and Fridge temperature not very cold
I can find only one good reason why your refrigerator may not be cooling. There is a control board inside the fresh food compartment and no signs of a defrost timer. If there is someone that go through some test to eliminate other possible problems would be good. If the refrigerator is still running, unplug and open the freezer compartment. Remove the back panel so we can have a look at the evaporator coils. Clean or are they frozen with a large piece of ice? Let me know, Thanks Sea Breeze
Posted on Mar 23, 2009
  • 396 Answers
SOURCE: My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Posted on Oct 20, 2009
  • 2468 Answers
SOURCE: fridge too cold
check the damper control and damper door between the freezer and refrigerator compartment to see if its iced up in a fully open position,if so thaw it out and then see if it moves as in opens and closes when the cold control in the refrige is adjusted,if not replace the cold control
Posted on Jan 17, 2010
  • 66 Answers
SOURCE: The damper is not staying open to keep fridge cold
What make and model is your appliance. Sounds like you have a fan problem
Posted on Apr 18, 2010
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
My refridgerator freezes the milk, How do i stop it from doing that? The temperature setting is in the normal range and the condensor coil is clean.
There are two setting on a fridge. One that sets the temp of the freezer and one that adjusts the temp of the fridge part. The fridge setting just adjusts the opening between the freezer and the fridge. So the fridge gets it's cool by stealing a little from the freezer. i'd get a fridge thermometer and set it it the fridge and see what the temp really is. The knobs in the fridge may not be accurate. Set the fridge and then move the thermometer over to the freezer and set that. Move back and forth until you get what you want. Usually the lower part of the fridge is a little colder then the top. However if you use the fridge a lot then every time you open the door the cold falls out and the fan will come on and start taking cold from the freezer. Another very cold spot is next to the vent where the cold air comes out from the freezer. Usually up top near the ice maker.
Sep 22, 2010 | Samsung RB215LASH
Oct 20, 2009 | Refrigerators
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
I have a samsung fridge, model # rs-2545sh
check the cold for what you want but the ideal settings would be 5 for the freezer and 37 for the fridge
freezer can be really cold but the fridge if too cold will freeze vegetables and lettuce
Jan 03, 2018 | Samsung RS2630SH Side by Side Refrigerator
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Refrigerators Logo
635 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
