Question about Acer Aspire 5050-3242 Notebook
No power thru power plug. my Acer Aspire 5050 will not recharge. It appears that the AC/DC plug or power board is defective. I've researched how to dismantle the laptop but am missing a couple of not so obvious screws and don't want to force anything. I need to dismantle the laptop to visually inspect the power board and possibly replace it. Does anyone have a service manual or knowledge to dismantle my laptop? Thanks.
  • 748 Answers
Hello
I have a schematic but it doesn't show a separate power board (although Acer does make alot of revisions). Look under the battery or under the CD tray for those hard to find screws. Acer likes to put sticky plastic circles over screws to hide them. Now unless *********** board is fried to a crisp don't replace the whole board just to fix a power connector. My company repairs these all the time for $50.00 labor + parts.
Posted on Aug 02, 2009
I have a Acer Aspire 5050-3371 Notebook. Before, I had a problem with it's battery and plug, so I disassembled it and found my DC input battery plug broken. I replaced the DC converter, and assembled...
Sometimes when the charger connector breaks, it shorts out the charging module on the motherboard, blowing it. It can also blow the external power supply.
If you can find someone else with a similar power supply, try using it. If that doesn't work, you've got bigger issues.
Jun 25, 2011 | Acer Aspire 5050-3371 Notebook
Either same problem or that you messed up your PC's board the more.
You might be having solder (lead) bridging two components together on the circuit board; especially if you were not careful enough when replacing the faulty DC converter.
This time around, maybe its good you take it to a professional electronics repair shop for assistance.
However, if you feel up to it, then take it apart and look closely at the components on the motherboard close to the DC converter for any undesired solder linking two components together (which ought not to be so).
Be carefule while at it. Best of luck
Oct 11, 2017 | Acer Aspire 5050-3371 Notebook
Battery can be used to power computer. Plug cannot. Tried a different power plug from a different computer with around the same voltage and whatts, but still didn't power. This is a DC in power plug...
The problem is most likely the DC connector in the computer. I have replaced many of these. Normally what happens is the connector is stressed by moving the computer while plugged in stressing the connector. It could also be the DC converter board but .... that would probably affect battery operation also.
To replace the connector, you have to completely disassemble the system down to removing the main board.
Jun 21, 2011 | Acer Aspire 5050-3371 Notebook
Changed the DC adapter plug it in orange light Problem with the Acer Aspire 5500 5532 5535 Laptop Computer (AS55702609RTL) PC Notebook changed the DC adapter plug it in orange light comes on charging I try...
If after the replacing the AC adapter the problem still persists , the power board on the motherboard has gone bad. The same can be repaired, but would require you to take the system in for repairs. if the system is under warranty then the best thing to do is get the motherboard replaced.
Thanks
proton
Nov 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5920-6864 wont turn on at all
Good questions.
You might want to try another power adapter first before replacing the board though.
If you do decide to replace the board I always use the same exact part number to avoid having to re-install windows, etc. You can do some research though to see if a higher revision will work. That info usually isn't available on the net though :(
If the board is available on the cheap then I'd say go ahead and fix this laptop otherwise lots of them are going for 200-300 this Black Friday ;)
Nov 20, 2009 | Acer Aspire 5920-6727 Notebook
Power cord attachment into the back of computer seems worn, it wants to run off battery instead of recharging through power supply
Either Have A Failing AC Adapter, Or A Failing DC Jack
you can test the AC Adapter using a multimeter (available at any home improvement center for $6)..
The DC Jack Would Need To Physically Be Checked To See If It's Faulty... which would intail removal of all parts down to the motherboard and visually inspect the DC Jack (the port where the Charger Cord Plugs into)
Remove The Battery... Plug AC Adapter Into Laptop.. Attempt To Power On....
Nov 15, 2009 | Acer Aspire 5100 Notebook
Power Board Problem and Power Button Hinges Top Cover broken
It would be cheaper to have the power board repaired but the replacement is around $55 from ebay. I'd get a new moulding for it if its available or even if you got somthing plastic welded up.
http://cgi.ebay.com/Acer-Aspire-3050-3680-5050-Power-Board-w-dc-jack-usb_W0QQitemZ120415274982QQihZ002QQcategoryZ158887QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope this helps
May 06, 2009 | Acer Aspire 3680 Laptop
Screen wont come on
what did you try already?
Mar 03, 2009 | Acer Aspire 5050 Notebook
Acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050 Power ON problems
that maybe the only problem. lets hope so.
Jul 29, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050-3242 Notebook Logo
204 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
