Question about Car Audio & Video
I connect to 6*9 speakers to 4 channel amplifier they give a bass but not sound.what should i do?
  • 97 Answers
Only subs should be hooked up to the amplifier the amp is mostly for bass anyways have your 6*9 just hooked up to the cd player itself to where its just for your vocals
Posted on Aug 02, 2009
I have a power acoustik 0V4-1200 amp and 2-12" kicker cvr dual 2 ohms. My amp keeps getting really hot and turning off. I have two pair of rca jacks from my cd player to the amp. One speaker hooked up...
i have found the specs to your amp. 1. Amplifier connections: Lets make things simple. As we look at the amplifier speaker connections, we will number the outputs 1 2 3 4 from left to right for the top connections and again 5 6 7 8 from left to right for the bottom connections. 1 should be connected to a positive (RED) (+) on sub woofer A on voice coil (a) 4 should be connected to a negative (BLACK) (-) on sub woofer A on voice coil (b) Now using a small piece of cable, connect negative of voice coil (a) to positive of voice coil (b) Follow the same procedure for the other sub woofer using 5 and 8 as 1 and 4 This configuration should make the amp run at 4 OHM BRIDGED x 2. i hope this helps. dreamsystems
Feb 07, 2011 | Car Audio & Video
Bass only going to rear speakers. How do I get
Hello michaelandta,
Check your filter settings on the front channels. It sounds like they may be set to "high pass" which would eliminate the bass frequencies. If you are using the amp to power normal speakers, it's usually best to set the filters for "full range". If the amp only has "low pass" and "high pass" settings, turn them both OFF.
Hope this helps.
Sep 11, 2009 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
We tried adjusting the VR2.0 bass amp gain but it barely pushes sound before reaching 20 or more and cuts off. I have 6 speakers but wired it just using 2 cables. Can that be an issue?
Not enough info 1). What is the impedence load of the speakers? I'm assuming you've wired three per channel. 2). Is your amp stable at 4/2/1/ or very rarely .5 ohms. Check the owners manual for the info.
Jun 25, 2009 | Reality VRA2.0 Car Audio Amplifier
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Connecting 4 bass speakers to one amp?
If you have a 4 channel amp and 4 speakers and each speaker is connected to each of the 4 channels you are just fine.
A stereo amplifier has 2 channels, typically labeled left and right and each channel has an amplifier. A 4 channel amplifier has 4 amplifiers. With one speaker on each channel, there is one speaker on each amplifier. Audio amps are referred to as amps or amplifiers, although if they have more than one channel it would be more correct to call them something like 'multi-channel amplifier' or 'multi amplifier speaker driver'. Semantics.
May 25, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Hooking up a new 8" woofer speaker to my amplifier
If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
  • Connect both left door speakers in parallel to Ch A Left.
  • Connect both right door speakers in parallel to Ch A Right.
  • Bridge Ch B and connect it to the new 8" sub.
  • Set the Ch A LPF/HPF to HPF.
  • Set the Ch B LPF/HPF to LPF.
This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
Mar 22, 2008 | Pioneer GM-6300F Car Audio Amplifier
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
