Modem and computer are not communicating.
The ethernet connection shows a green light (led) on the modem. There is a solid orange light (led) on the lower side at the computer connection and an upper light that flashes yellow/orange on occassion. I have reset the modem, changed cable ends, changed cables. The computer test say that the Intel 82562V 10/100 Network connections is operating properly. All of the lights are green on the '2WIRE' modem. What is there to do???????????????
  • 1 more comment
  • avalanchemcd Aug 02, 2009
    2WIRE modem from ATT
  • Michelle Crabbe May 11, 2010
    What type of modem are you using?
  • Brett Duxbury
    Brett Duxbury Jun 28, 2017
    make and model number ?
    operating system of computer is it windows 10 or something else ?
    Is there a router ?
    Is the modem a router also ?
    is there an ip address for the modem and an ip address for the computer ?
    what are the subnet masks of both ip addresses ?
  • Computers & ... Master
  • 1,830 Answers
Are all your connections in the appropriate place? Did you press and hold the re-set button on your router for 40 seconds and wait until all the lights are green on your router?
Posted on Jun 28, 2017
Randy V
  • 236 Answers
SOURCE: Broaband link
Ok, thank you for clarifying.
It seems like the settings on the 1707 have been reset.
On this modem, while connected, type "" without the quotes.
  • click on "Broadband Link"
  • click on "Advanced Settings"
*note:you may have to enter your password. if you never set one and it asks you for one, click on "I still can’t remember the password". Follow the instructions.
  • On the "advanced Settings" page, make sure your settings are correct. The user name is the same you use to check your AT&T Yahoo Email. and also the password.
  • If you have forgotten your settings, you can call AT&T to retreive your settings at 1-877-722-3755. Have your AT&T Bill and the debit/credit card (used to activate your service) on hand.
They should be able to give you your info.
If not, comment back.
Posted on Aug 04, 2008
  • 6 Answers
SOURCE: Intermittent DSL connection
hi, i happen to be one of the technical support agent of this dsl modem/'s very simple...there are a lot of factors that may cause the intermittent could be the filter if it's hard wired, or EMI's... or defective ethernet cable...however, if it's wirelessly connected to the computer...there could be problem like slow browse, no browse or no connection at all if there's a wrong configuration of the modem...
Posted on Dec 29, 2008
  • 82 Answers
SOURCE: 2wire 2701HG-B gateway can't connect locally
Have you got MS CLient loaded in the network settings. If not run network wizward on each machine and then try again. hope this helps Mark
Posted on Aug 18, 2009
  • 597 Answers
SOURCE: 2wire ethernet and wireless lights blinking
They shouldn't become solid. Most lights blink when there is a communication between the devices. It's never a solid connection light.
Posted on Oct 04, 2009
  • 4 Answers
SOURCE: my 2wire has the power light red and the ethernet ...
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at about 18 mos to 2 years. Mine is almost exactly at 2 yrs.
I replaced the power cord and now it works fine. You can order the OEM replacement from att e-store or try Radio Shack for a universal cord.
Posted on Jun 09, 2010
Emachines Will not detect ethernet cable
With the machine on and the cable connected on both ends (1 to computer and the other end to the Router or Modem that needs to be powered up) look where the cable plugs into your computer. Is there a green or orange light on. There may be two. Normally one that stays on steady is the CONNECT. This one is normally green color LED. When Data is being transmitted a second LED will be flickering showing data transfer. If you have no LED lights showing directly by the Ethernet cable, try another cable. Reminder: also make sure you have power on the router/ cable/dsl modem.
Hope this helps..
Nov 04, 2012 | eMachines T5062 PC Desktop
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Haw can i install Belkin wireless router N300 without the CD
You can easily follow the following steps to install it without a setup CD
Step 1: Please find a compatible power source and plug your modem into it.
Step 2: Now, you can connect your computer to the modem using an Ethernet cable without the router being installed.
Step 3: please verify whether your computer is receiving an internet connection or not. Just click and access any website of your choice.
For more details kindly visit How to Login Netgear Wireless Router Routerlogin net
Apr 10, 2012 | Belkin F5D7234-4 Router
Hi. I have a 2wire 1000hg modem/router. I pluged in the device and the green power LED light is on and solid green. The other two LEDs for the Boradband connection and Local Network are on and both are...
Plug it into another known working computer. If that one also does not work then the issue is with the modem/router. If it works then the hassle is with your initial witch.
Mar 03, 2017 | 2wire HomePortal 1000HG DSL Modem and...
How many lights should be on my westell model327w?
The Westell has several lights on the front that have various meanings
Power = When lit, this light indicates there's power to the router. It should be solid green.
Ethernet = When lit, this light indicates that the modem is communicating with your computer. This will be on only if you're using the Ethernet cable to connect the modem to your computer
Wireless = When lit, this light indicates that the wireless function of the Actiontec is working. This will only be lit if you're using the wireless function.
DSL = When lit, this light indicates the modem is speaking to the central office (phone company). When working, the light should be solid green.
Internet = When blinking, this light indicates that you're receiving information i.e., you're able to browse from site to site. This light will be blinking as you're receiving information.
Sep 16, 2010 | Computers & Internet
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
Siemens Speed Stream 4100 modem - worked last week - now no lights
This modem is for AT&T broadband only and requires AT&T software to function.
Jan 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
