The light for the drivers side and isn't lit on the overhead and when you press the button it makes a buzzing sound as if you were driving and the door is open or someone tries to open the sliding door while driving
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicle- cars, atv, trucks. forklifts, boats, excavators etc.
SOURCE: 2006 town and country passanger sliding door problem
I've leased two Town and Country vans over the past 4 years, and actually purchased the latest one after the lease. In both vans the sliding doors, normally the drivers side, reacted teh same way. If the door was closed it would open, stop a one point, and then return to the open position. At times I could get it close. But over time the doors stoped working all together.
It is not due to the switch or the motor. Most cases like this (in in both of mine) it is due to the repetitive use of that door, and the realitive inflexibility of the wire harness. Over time, and with more uses (in my case the driver side sliding door was used alot) the wire in the harness fails. Picture it as a willow branch. One snapped off of a tree it first is green and flexible, and bends pretty well into any form. But over time, with age and repetitive bending, it will break.
The only recourse is a new harness, as the wire/wires are broken somewhere in the harness (the belt chain in the lower track of the door). I was temped to take it apart and try to repair it myself, but as the parts were under warranty (I have the extended 85,000 mile), I opted to have the professionals handle it. The repair without the warranty is under $200 typically (parts and labor). Good luck.
SOURCE: Venture van power door problem
It sounds as though one of the proximity sensors is faulty. Also try giving the tracks for the door a good shot of white spray lithium grease. The door may be binding enough so that the emergency reverse is kicking in.
SOURCE: 2007 Kia Sedona van power sliding door
i just had to have this fixed on my 07 sedona on the bottom arm for the doors there are litle lock solinoids that go bad i would take it to a dealer to have it checked for the switch you can turn the power off to the doors and open them manualy but they are hard to open because you are pulling the cable instead of the motor doing it and this will not hurt the doors
SOURCE: 2005 Toyota Sienna LE Driver Side Power Sliding
Try this... it fixed my problem whereby the 2005 Toyota Sienna passenger sliding door would sometimes open and sometimes not, yet I could hear the motor trying to open/close it. It cost me 20 minutes and 10 drops of oil, not $1200.
First, get the door open. It took me two weeks of constant trying, but it finally opened.
Next, remove the plastic covering of the inside door handle this way: locate the two screws on the forward edge of the sliding door near the child-safety switch: (the switch is a small lever near the door latch, on the forward edge of the door) loosen and remove the two phillips screws, one above the child-safety latch, and one below.
Remove the plastic cover to expose the gears for the door open/close mechanism.
There's a bunch of intricate plastic and metal parts in there, all coated with white grease. I used some 3-n-1 oil to lubricate everything in there thoroughly, In my case, there was one part that was a little void of grease, hence it "stuck" occasionally.
Test the system. If it's Okay, replace the plastic cover, and re-install the screws.
Now my Toyota Sienna 2005 door never fails to open or close.
SOURCE: 2004 chevy malibu maxx-driver side
Hello and welcome to FixYa!
You definitely have a faulty trunk actuator. The trunk actuator controls the lock and unlocking movement. If it's faulty it won't work, you may just here a noise on the button but a faulty actuator won't open the trunk. I strongly suggest that you have it replaced to resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
