Question about Nokia N70 Cellular Phone
N70 - Music player memory & Operator logo
two problems im facing with the N70
1. I have 800mb free space on my phone, yet when im trying to save a song file (mp3) which i received via bluetooth onto my phone into the memory card it says not enough memory. the song is abt 2 mb.
2. i downloaded an operator logo which i want removed, however cant seem to find the option to turn the operator logo off.
Re: n70 - Music player memory & Operator logo
This is Yogesh, i m using Nokia N70 for last 1 year just i want to ask how to move application data & documents into memory card.
Just mail to :-
Cell :- 9880227974
Posted on Feb 21, 2008
    Problem Solver:
  • 9 Answers
The N70 only has 22MB of built-in memory, and all incoming bluetooth files go directly to the onboard memory (inbox) before you can copy or move them to the memory card. Try freeing up some of the system memory by using the "move to memory card" option and then try to get your song again. :)
Regarding the other issue you are having, the oplogo should be located at the location below, and is always displayed. If you want nothing displayed there, you can replace the image with a solid color of the background of your choice by editing in photoshop or similar program.
This is a 97x25 pixel file, and is named according to your Country Code, Network Code, and Subnet code. There may be several files located here, as they change when you 'roam' around, and you can edit any number of them to your liking.
Hope this helps, please let me know if you have any questions!
Music player- Not enough memory to perform operation, delete some data first.
Posted on Nov 25, 2007
  • 178 Answers
Try the following things:
  1. Ensure your memory card has enough free space;
  2. Close all applications that may be running in background due to auto start option you might have selected. You may do this by pressing and holding the menu key until the list of applications running appears, and you may close each applications by pressing the 'c' key.
Posted on Nov 27, 2007
0 characters
3 Points
My phone is nokia n70 . my nokia n70 change automatically function. come to the visual redio and music players many times.and not any work that time hang position finally i switch off my mobile
your phone might be hanging because u don't have enough memory space on the phone memory, try freeing up some space by deleting some items like media files that is stored on the phone's memory. Hope you know that for the visual radio to work you must connect a headset to the phone to act as the antenna.
hope that helps
Jul 30, 2011 | Nokia N70 Cellular Phone
Music player:Not enough memory,N70
You need to buy a memory card that has more GB like 2 or 3GB
Feb 11, 2011 | Nokia N70 Cellular Phone
Same problem too -help, what should i do?
u can try to change your messaging memory go in your phone messaging/settings/other/memory in use and change to phone memory now u can sent and rec mp3 thx
Sep 20, 2009 | Nokia N70 Cellular Phone
Music player got some sound lock
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
before formatting first save all your files in your memory card including your calender, notes, contacts everythings and remove your memory card before formatting..its important that your mobile should be fully charged
Sep 29, 2008 | Nokia N70 Cellular Phone
Music Player: Not enough memory to perform operation delete some data first
nthing to worry change ur message setting ,put memory card memory as memory in use. after cahnging tht u cn easily save ur files to ur memory card
Feb 19, 2008 | Nokia N70 Cellular Phone
Cannot save music files
look 800mb free space is on the memory card ok
so if you have any files saved in phone memory transfer it to memory card
if you recieve any song from bluetooth the phone memory should be double than the file you are recieving so try the other solution.
i give you a code that will not erase any data *#7780#
Nov 29, 2007 | Nokia N70 Cellular Phone
N70 issue
Ok first,transfer all your data to memory card using fexplore or file manager then check ur phone memory if it dont work try this 1. first type dis code *#7370# then press yes and then put your security code and it will format ur phone.
WARNING: remove ur memory card and try the second solution
and all data of phone memry will b erased
Nov 27, 2007 | Nokia N70 Cellular Phone
go to message menu then press options and press settings and come down to other press that and change the memory options to memory card instead of phone memory hope it works
N70 comes on with whie screen and hangs
a lot tobe done in that problem of your... but i can give you one of the best... place yur unit in table so you can be cmfortable...the press all the keys in same time these keys are key *,key3,the call,and power on switch... much better if you had buddy beside hold the unit... press them in same time or together, dont release it until you dont see a word formatting... wait until it finsih and the unit will be restarted by itself... enjoy
Nov 14, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
318 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
