Pushing the power button on Dell Dimension 4700 C does not turn on the PC. Power button flashes amber and continues like that.
  • kurteise Aug 02, 2009
    Dell Dimension is a desktop PC. Where is the battery?
    Brigadier General:
  • 7,191 Answers
The power button flashing amber suggests that there is an internal power problem.
If you can handle such repairs, open the PC cabinet to check all the connectors on the system board. There might be some connector which has become loose.
Also, let us know if the PC gives out any beep sounds and whether you have made any hardware/software changes recently.
Hope this solves your problem. For more help and clarifications please reply to this post. Thanks.
Posted on Aug 02, 2009
    President:
  • 1,257 Answers
Just remove the battery for few hours like 4-5 hours and then try to start using direct supply from adapter. If it works well and good else connect the battery again to see...This should do the trick...if none of this solution work then please contact local computer service to find the faulty hardware and its replace it...........Thanks.
Blinking amber power button dell 4700 c / light blinks & after a while it boots. when its running its fine works with no problem. Is it power supply. bad fan, coms - battery , or hard drive . or all...
first remove your memory and clean it with a clean cloth the remove the processor fan and clean the surface ot the fan an the processor then apply a thin layer of heatsink compound and fix tightly to the socket
Apr 27, 2011 | Dell Dimension 4700 PC Desktop
I have a Dell Dimension 4700, the problem is that recently, i went to start it up, nothing would happen, the 4 ABCD lights don't light up, and i notice this steady amber light. So it was determined that a...
You can try to reseat the CPU (processor) chip. Inorder to do that you have to remove the heatsink and then reapply thermal paste (compound) to the surface of processor. The processor rarely goes bad.
Apr 09, 2011 | Dell Dimension 4700 PC Desktop
Dell dimension 5100 - usb ports on motherboard are broken
Flashing Amber is normally power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The USB ports are part of the motherboard
Jun 08, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell desktop 4700 problem
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
If the LED Is SOLID amber, it is likely either a component connected to the Motherboard or a bad motherboard
May 15, 2010 | Dell Dimension 4700 PC Desktop
Tower power button flashes amber but will not start
May 13, 2010 | Dell Dimension™ E510 PC Desktop
Dell Dimension power button flashes amber and will
open up your system get a can of air and blow all dust away could be an overheating fault
I turned on my Dell Dimension 4700 computer,but the amber light started to blink . I held the start up button for 5 seconds and the light went out. I tried to start it up again and got the same thing,...
Vaughn it sounds like the power supply is going bad, try another known good working power supply. If that doesn't work then the motherboard would need to be replaced. If the power supply isn't giving the correct voltages that could cause the computer not to turn on. If the motheboard isn't able to convert the voltages properly then the motherboard could be faulty.
Dec 23, 2009 | Dell Dimension 4700 PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
k24674
