Question about Whirlpool Duet GHW9150P Front Load Washer
It stops in the middle of a cycle and gives an F02 problem.
  • 6,784 Answers
F02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Aug 02, 2009
4 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: the washer right in the middle of a wash cycle it
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
  • 107 Answers
SOURCE: Washer has an F02 code in the middle of the cycle.
F02 = Long Drain
"F/02" is flashed.
The most common cause is a clogged drain filter. Remove your lower front panel. The filter is located in the discharge hose before the pump (often white in color).
Remove the filter and clean out any debris (socks, nails, coins etc..)
If this is not the problem then here is directly fronm the manual.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the
pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Posted on Dec 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: my kenmore elite washer is stopping mid way
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
It doesn't finish the cycle and stops and flashes F02
Possible that the drain cycle is not active and so the program trips off. Check the drain for clogging , check the power to the drain from the controller during the cycle, if there is no power the program controller is faulty.
Jul 02, 2012 | Baumatic BTWM4 Front Load Washer
My oven is saying "stop" . Previously to this is was showing F02 and the fan wouldn't turn off. We turned the main switch for oven off and back on and it now says "stop"
Previous fault F02 is indicating an overheat fault- service manual says to replace main electronic control board. However, switching off at wall has reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears- sometimes switching off at wall will clear fault. Good luck!!
Mar 16, 2010 | Whirlpool AKZ159IX Oven
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer has an F02 code in the middle of the cycle, which has stopped, and I don't have the manual.
F02 = Long Drain
"F/02" is flashed.
pump is running.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02/Sud error message fabric softner will not dispense
The pressure switch is sensing that there is still water in the unit,it sits at the top of machine under the top cover,it is round and usually red in color remove the hose/tube from it and blow through it to make sure it is clear,you can also remove the switch itself and lightly blow into it you will hear a couple of clicks put it back together and give it a shot..
Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We get a F02 error relating to drain
F02 is the code for long drain. Your filter on your pump is probably clogged with lint and other stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
652 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
