Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I have a Philips Magnavox ptv843 and it has a red tint. The picture is really dark, I can hardly see anything in dark seens. I tried to adjust the contrast and brightness but no help. Thanks
  • 167 Answers
These TV's are known for polluted coolant in the picture tubes.The coolant is between the lense and the tube. The factory has a Service Bulletin about this problem and they say to change the coolant in each picture tube. This will make the TV look like it did when it was new.
Posted on Aug 02, 2009
Magnavox 9P6034C 60 in. Rear Projection Television Problem. The problem I am having, is that I can not adjust the tint or color, or brightness, whatever I adjust makes no difference. I can move the tint...
This is a common problem with RP Televisions unfortunately. Usually means the tubes are going out. It can be repaired (usually) but it cost quite a bit to fix unless you could do it yourself (which I don't recommend) If that's not an option I suggest going out and buying a new tv. I recommend and LCD or LED though. Not a plasma or rp
Nov 28, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture on my magnavox 9p5544c102 is fuzzy with green tint
Its the CRT coolant which needs replacement. You can get the Phillips CRT coolant kit at www.tvrepairworld.com which contains the Coolant for all three CRT's plus has the CD with instructions.
Jul 14, 2010 | Philips 9P5544C 55" Rear Projection...
I have a 55 inch phillips magnavox t.v. Im almost positive its a projection t.v., my problem is that the picture shows up really dark, you can see when the show is a bright show, but comes up a weird...
I would say your small signal module is bad. This is the board with the convergence ICs. Have a tech or yourself pull the board out and replace the ICs and some resistors. Checkout TVREPAIRKITS.com. They will have your model and its symptoms. Hope to guide you in the right direction!
Apr 29, 2010 | Philips Magnavox 55P9271 55" Rear...
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
Magnavox PTV910. The picture is good but color is bad
the coolant in the blue and green crts has congealed which is causing the red tube to become dominate. The coolant can be changed at home. You can get the phillips coolant replacement kit at the following link which contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 15, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Sep 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
389 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
