I have a Panasonic PT-50LC14 TV, it has a yellow cast on screen in the lower left section of the screen. Where can I get the installation instructions for the blue polarizer filter, LSXA0600? Is this something that I should be able to do? Thank you. johndmckay@comcast.net
  • johndmckay Aug 02, 2009
    Thank you for your response. Do you know where I may be able to get a service manual, I am sure I could replace the filter, just not sure where it is. I have a good idea. And, from what I read, will this require some sort of re-alignment?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You can replace the blue polarizer by following the procedure--
Remove ALL connectors and unscrew and remove the entire C board. Don't worry about marking the connectors as they are all keyed and can only be placed on the board correctly. Be careful of the headers connecting the C board to the riser boards below it. Refer to diagram 1-2-4 (C-Board Removal)
Be very careful when unhinging and removing the three ribbon cables from the LCD panels, as the plastic is VERY brittle on the little snaps that hold the cables in place. I broke one side of one of them and had to use a bit of epoxy to hold it back in place.
After you remove the c board you can remove all the polarizers. Remove the screw and you can slide the Blue OUT Polarizer straight up with fine tweezers
If you burnt one of them so bad that the blue is weak, you have burnt both of them to the point that they will need to be replaced as a set.
This is how a burnt polarizer will look like—
Burnt Polarizer
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 02, 2009
  • 305 Answers
Have a look here john, and from what ive read, you should be able to do it yourself...
www.prontotech.com
here is a link to a site that may be able to assist you in your repair quest,,,good luck...
http://www.avsforum.com/avs-vb/showthread.php?t=1157338
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
Tip
Panasonic PT50LC14 Manual Download
Download Panasonic PT-50LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-50LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-50LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Anyone know how much a light engine might cost for this tv panasonic PT-50LC14 50 In.
to be honest save your money and buy a new tv, by the time you purchase it and install it , your still gonna run into more problems.
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Yellow tv screen
i have the same problem. I had to take the whole thing apart and found that the red filter has a burn pattern in it. I am still trying to find a red filter for it.
Feb 16, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Stained Screen
You have a bad light engine.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Feb 20, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
477 people viewed this question
Top Televison & Video Experts
