Question about InFocus ScreenPlay 4805 Multimedia Projector
Shutter doesn't open all the way leaving a dark section on the right from top to bottom
  • 2,237 Answers
There is no shutter in the projector. that dark section you see is part of the light tunnel that is collapsing. it is a 4-sided mirror tube, and the glue breaks down in excessive heat. it needs to be replaced. part # 306-0095-00
Posted on Aug 12, 2009
    Champion:
  • 363 Answers
I would have the unit serviced to clean all shutter components and lubricate
Posted on Aug 02, 2009
How to set the shutter speed on the sanyo vpc-e2100
Actually, you can set this cameras shutter time by 1) Set top knob to M 2) Make sure that the bottom of the screen displays this "OK: Adjust" in yellow letters, and below this it tells you the the F: variables, and the Shutter speed. From what I have experienced, this only goes up to 15 seconds. But, this is great for light painting in total darkness!!!
Jan 27, 2012 | Cameras
The lens shutter doesn't open to display picture
If this is a Kodak Slide Projector, it is equipped with a "dark shutter", to keep blinding the audience with white light when there is no slide in the optical gate. The shutter is spring-loaded, and there is an adjustment required in order to make the shutter operate correctly. Your projector either needs a spring, needs the spring re-hooked to its mount or and adjustment to the trigger. Kodak still has service manuals on their support website, or contact: www.micro-tools.com for parts and assistance (they purchased all Kodak's repair parts). Good Luck!
Sep 01, 2011 | Office Equipment & Supplies
Hi! I've just bought a Lomo LC-A on ebay, and it seems that the shutter doesn't work properly. It opens and closes, it doesn't get stuck, but there's only one click, even when I put it in...
It's got ONE speed - 1/100. It's designed to use ISO100 speed, outdoors in daylight, or with flash, using sunny 16 exposre. These are incredibly basic machines similar to Holgas and Diana's. 1 or 2 f/stop choices, 1 shutter speed, maybe a flash connection.
Jul 07, 2011 | Lomo LC-A 35mm SLR Camera
Maytag model #mtf 2156ge freezer is good and cold,everything still frozen, bottom is not cooling
check to make sure the shutter between the freezer and refrigerator section is operating. The shutter has a small motor that opens and closes on the refer side thermostat. The shutter is what lets the cold air from the freezer circulate into the refer compartment. Could also be a bad thermostat in the refer section.
Dec 29, 2010 | Refrigerators
The bottom door is not closing right. I can slide
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
COLD GARAGE
Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 02, 2010 | Kenmore 64802 Top Freezer Refrigerator
My dyson seems to have lost suction?
If the usual clog clearing and filter cleaning doesn;t work-> I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Nov 22, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Televison & Video
Dark Picture
I am assuming the following two things.
1. The part was indoors.
2. You are using the 18-135 mm lens with the Nikon D80.
The problem with shooting indoors is that not enough light goes in through the lens to the filter. Solutions:
1. Use the flash with every shot. In case there is not flashlight available, use the on board flash. Press the top button behind the barrel on the camera. It has a lighting icon. It will pop open the flash. If you are in 'P', 'A', 'S' mode, the camera will sync the shutter speed with flash. If the camera is on auto mode (The green camera icon) the flash will pop up and fire by itself.
2. Use the lens with with lowest f stop, i.e. with bigger aperture.
3. Increase ISO. You ought to get usable photographs right up to 800. To change ISO, press the button on the back of the camera which says 'ISO' (Second button from bottom) and turn the primary command dial simultaneously to change ISO setting. Higher ISO speed = Lower shutter speed (But less clarity too).
Hope it helps.
Satdeep
Jun 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
InFocus ScreenPlay 4805 Multimedia Projector Logo
234 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
