Question about Curtis DVD6041 System
5.1 CH HOME THEATRE SYSTEM I DO NOT HAVE THE DIRECTIONS FOR HOOK UP
  • Daniel Bakewell May 11, 2010
    Need more info really, are they active or passive speakers (does the woofer have its own power source and connections for the other speakers (Brand, model??)), and what do you want to hook up..list everything
  • 691 Answers
Manual available here
http://www.curtisint.com/web/browser.asp?productID=DVD6041&catName=&brand=CURTIS&manual=DVD6041
Posted on Aug 02, 2009
Tr-606 directions for use and remote
As long as your television and system both have (audio/out jacks from tv, audio/in to system) and cables it should hook up. Not real sure what you mean about directions for the remote, the system I have didn't come with directions just starts working as soon as the system is hooked up. Hope it helps
Feb 08, 2012 | Yamaha 5.1-Ch. Surround Sound Home Theater...
How do you get sound to come from tv out of speakers of home theatre system
It just depends on the tv you have. If you hook up the RCA jacks to the (Audio out) of the TV into one of the (AUX in) ports of the home Theatre system you should be able to geet the sound that comes from the TV to play out the theatre system. If you are watching through a cable box you will need to hook the RCA cables to the cable box (Audio out) too the theatre systems (AUX in), in insted.
Mar 05, 2011 | Televison & Video
I bought a new Samsung home theatre system with wireless rear speakers and followed the directions to hook them up, but the reciever flashes rear check. this has been going on for 4 hours
HI,
SPEAKER SYSTEM HAS TWO MAIN UNITS ONE IS ADD ON UNIT AND INTEGRATED WIRELESS SYSTEM.TRY TO MATCH THE POWER HANDLING OF ADAPTER WITH THAT ON YOUR REAR SPEAKER OUTPUT.
TNKS RABBANEES
Nov 04, 2009 | Audio Players & Recorders
No sound from home theatre system for TV
Have you plugged in the audio output of your tv to your home theater system? if not try it, sometimes it helps.
Jun 09, 2009 | Sony HT-DDW700 System
Connect home theatre to ps3 to 32" lcd tv
if your tv and home theatre system as all hdmi or component hook ups then follow these steps but only use all one or the other cables.
1. hook the cable from the ps3 to the home theatre "imput slot" (you choose which one you want to use)
2. hook a cable to the output slot on the home theatre system to your imput slot on your tv.
3. turn on all three systems, put your home theatre system on the correct function (which ever slots you decided to put the cables in to the input slots) then turn your tv to the correct AV channel
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Multiple game systems through home theatre
what you need to do is hook all of your gaming systems into the "in ports" on your gameing switch, then hook the set of cables you want to use to the "out port" then the other end of those cables need to go to the "in port" on the home theatre system (you can pick which in port you would like to use, it should say which is which on the back by the ports) after doing this you need to find the out port on the home theatre system that corresponds with the cables you are using ie, rca component or hdmi. once you find that port you need to hook a cable to that into your 'in port" on your tv., lastly turn on all of your gaming systems, your tv and your home theatre system. and on your home theatre system select which ever port you hooked the gaming switch into, then turn your tv to the correct channel that you hooked the cables into the tv, lastly go through each swithc on your gaming switch to be sure that they all work, if not, you might want to use all the same cables for all connections, ie, all component all rca or all hdmi, i prefer component.
Mar 29, 2009 | Philips MX6050D System
Hi can i connect my transcend mp3 player directly to my home theatre so that i can get the music output in my home theatre speakers , if i can please suggest how?
easy, just find the AUX port on the home theatre system then turn the system to AUX and hook a cable that has 2 male ends (the ends that go into your mp3 players headphone jack) to your ipod and to your home theatre, you will have to buy this cable seperatly
Jan 03, 2009 | Transcend T-Sonic 840 MP3 Player
I'm trying to get the xbox working through the home theatre system but I'm still getting the sound from the TV which has intergrated freeview. The Xbox is connected to the TV using an HDMI cable, the home...
you need to hook up the xbox' audio cables to the home theatre systems AUX in port and then have your system set on AUX, and you can leave your xbox' hdmi plugged into the tv, just be sure your on the correct AV chanel.
Dec 24, 2008 | Panasonic Home Theater System System
Have pitcher no sound with my home theatre system
use an optical cable from your ps3 for sound to your amp, or use the red/white rca's on the cable the ps3 came with to go directly to your amp.
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Curtis DVD6041 System Logo
172 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
