Question about Cycling
Dynacraft Slumber Party 20 inch girls bike
Just bought a girls Dynacraft 20 inch Slumber Party bike from Walmart, as well as a set of Bell adjustable training wheels from K-Mart. Rear threaded axle doesn't protrude out far enough to mount everything - what's up with that?! any suggestions?
  • Anonymous Mar 17, 2014
    I need to know the length of a Huffy 20 inch Coaster Bicycle rear axle as i need a longer rear axle to mount heavy duty training wheels on my daughter's bike.
    President:
  • 1,138 Answers
Make sure you follow the directions carefully. You might try leaving the flat washers out or substituting thinner ones. Worse case you will have to go to a bicycle shop and purchase a longer axle. Make sure you keep careful track of how you disassembled it and take pictures or make drawings. The hardest part with replacing an axle is getting the proper resistance on both sides so the bearings don't bind. Check www.sheldonbrown.com for some helpful articles.
Posted on Aug 03, 2009
Dynacraft Girls 16" Barbie Bike pedals don't move
The problem could be the coaster brake hub, it could be that the cranks are not properly adjusted, or any number of other weird things. My advise--take it to a bike shop. If they're kind, they should be able to get things moving in the proper circular motion quickly for a reasonable charge. If they're not kind, they'll laugh at the bike first, but they will still help.
Dec 28, 2013 | Dynacraft Girls 16" Barbie Bike
Chain coming loose
Yes. Loosen the two nuts on the back wheel. When they are loose just pull the wheel back until the chain is tight enough and tighten nuts while holding the tire in the proper position at the proper tightness of the chain. Make sure that the tire is running true when tightened.
Jun 24, 2012 | Dynacraft Cycling
The very first time my daughter rode her new 14" Dynacraft Barbie bicycle, one of the tassels came out of the side of the handlebar when she laid it down. How can I get a replacement tassel/tassels?...
I went to a five and dime and bought streamers for my kids, they made their own and had a blast doing it,, you can use a ziptie, once they add all the colors they want, and stuff that in the handlebar grip hole to mount them,
May 28, 2011 | Dynacraft Girls 16" Barbie Bike
How do i raise the seat on a dynacraft tony hawk bmx bike
loosen seat post clamp with correct size allen. once its loose push down and twist the seat untill its where you want it then tighten the seat post clamp
May 17, 2011 | Dynacraft Tony Hawk Homer Boy's 20-Inch...
20 inch Slumber party bicycle will not accept training wheels? Rear threaded axle is not long enough to allow for training wheels (that i cna find)
Yes you can add training wheels to this bike. The origional axle is too short, however, if you are mechanical enough, you can remove the axle and buy a longer one. I did this for my daughters bike, and for abot 5 dollars you can pick up a longer axle which will accept training wheels. But be warned, there are several bearings and you need to place them back in the correct position or the bike will not work.
Dec 27, 2010 | Dynacraft Cycling
16 inch bicycle tire is flat. Need replacement, where to buy?
Call Dynacraft (bike maker) at 1-800-551-0032. My daughter's rear tire was flat and they sent out a new tube for free. She had the bike for only about 4 months. They also sent out a new rear tire as bearing/coaster brake assembly was make noises. The only problem is her original rim was purple and they sent out a silver colored rim as they don't have purple replacement part. I also had to install the tube and tire on the new rim. They only send replacement parts not assemblies.
Sep 16, 2010 | Dynacraft Girls 16" Barbie Bike
Where do I find a replacement tire for a barbie dynacraft bike?
Its either a 12" or 16" tire replace with any tire you like in that size
Aug 16, 2010 | Dynacraft Girls 16" Barbie Bike
How do you change the inner tube on dynacraft slumber party bike. I can't get the wheel off.
What do you mean you can't take the wheel off if a man/person put it on you surely can take it off, step back look at the situation and get er done!!!
Apr 08, 2010 | Dynacraft Girls 16" Barbie Bike
Where to purchase new training wheels for the dynacraft barbie 16 inch bike? st. pete, fl
I see at least 7 bicycle shops in your area. The training wheels don't have to be made by the same company that made the bicycle. Phone around to the various shops and give them the same info you posted here. If you don't feel comfortable installing them yourself the shop you choose will be able to install them easily. Please let me know if this helps.
Nov 19, 2009 | Dynacraft Girls 16" Barbie Bike
Cycling Logo
581 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
