Question about Acer Aspire 3680 Laptop
No disply nearly i got problem that when i restart my pc i wont get the disply again..hope i will get good solution.......
    Problem Solver:
  • 9 Answers
It may be problem with ur memory. Open the cabinet and take memory from slots. Clean the slot and memory. Refix it.
Try this one
Posted on Nov 25, 2007
Windows wont boot past the first xp screen restarts again and again in a loop and pressing f8 doesnt work wont le
In that case, place your System disk in the DVD/CD drive after setting the BIOS to CD ROM first boot and boot the machine choosing repair system from the menu.
Hope this helps.
Dec 30, 2010 | MPC Computers ClientPro 365 PC Desktop
If the unit will not turn on and has no power, tried the restart ac and battery out
Hi! The problem could be on the motherboard thats why it wont turn on. There may be blown capacitors that needs replacement for it to work again. Hope this helps and have a good one!
Jun 10, 2010 | Computers & Internet
No disply of my motherboard plzz help mee.
Good day sir/maam, hi, if your motherboard wont turn on, you need to make sure that these 5 things are in good order. (By the way, disconnect everything except these listed 5.)
  1. (PC is on) Your power supply, make sure that the exhaust fan is spinning as you turn it on.
  2. (PC is off) Your memory module, (ddr1 or ddr2) clean the contacts using an eraser(pencil) the gold plate contacts and a clean brush your motherboard memory slot.
  3. connect the casing's pc speaker on the motherboard.
  4. connect a video card, make sure its good. If you are using the motherboard's VGA, dont connect a video card. Temporarily reset the CMOS, use or locate cmos battery jumper setting. usually its 1&2 set the jumper to 2&3, then back to 1&2. connect a good monitor.
  5. Connect a keyboard.
Now power on your PC, check your Keyboard, you should see two sets of lights: first set (NUM LOCK + CAPS LOCK + SCROLL LOCK) then a few seconds the second set (NUM LOCK only). at this point you should hear a beep from the PC speaker.
If not, you may hear 1 long and 3 short beeps. bad video card. OR continous beeps, bad motherboard.
If you did not hear anything, do it all over again several times.
Still not working? replace your motherboard, its bad.
hope this helps.
Oct 10, 2009 | Dell (E210882) Motherboard
How to format the desktop,which is affected by a virus(trojen)?
Boot from your system disc and do windows over again,and then go to format selected partition. First go to your bios and go to boot disk priority then select first boot device on boot from disk. Then exit and safe with changes. Put your system disk in and there you go
Oct 06, 2009 | HP Compaq Presario SR1830NX PC Desktop
Disply Problem
its a driver problem, my bud had the same probs with a older nVidia but gives same BSOD msg. just up date the drivers or reinstall them. all picked out for ya just C&P it. oh and after downloading new drivers uninstall the old drivers in the add/remove, restart and turn off the found new hardware wiz then install new drivers and restart again. sad to say that the BSOD was only hapaning cuz my buds card was dieing. hope that yours lives =D
Jun 09, 2009 | XFX GeForce 6200 Graphic Card
Machine won't start after opening door near end of cycle
Unplug the machine for about a minute. then plug back in. It restarted on its own.
Apr 29, 2009 | Washing Machines
I have problem my pc runing some time suddenly come blue screen and disply appear theare is error ati2dvag incolding this error i restart the pc it come normal
well make sure you did not installed incompatible programs and driver in the system this might course file curruption or system scrash which will lead to blue screen of death.
try restor your pc from the previous good and stable mode
Dec 16, 2008 | Computers & Internet
Lcd monitor viewsonic VA702b MODEL# VS10781
This model may have a worn out capacitor, C808, 1000uf @ 25V. It is in the middle of the power supply board.
I have fixed many.
Monitor Mike
Aug 09, 2008 | ViewSonic VA702b 17" LCD Monitor
Sytem Wont Start
Hi suisboy,
This sounds similar to a problem I had with a clients PC. The best way to debug this is to swap out one component at a time and see it it fixes your problem. However, if you can't do this then I'd suggest you try the following in this order.
  1. Remove all cards from the PCI bus leaving only the graphics card in place.
  2. Unplug all drive cables from the motherboard and power from the drives.
  3. Try to boot the motherboard. If successful try this, several time and if you don't have any problems you are okay to proceed.
  4. Enter the BIOS and load load the Default settings.
  5. Enter the BIOS and make it run the system check to fully test the memory.
  6. One by one re-attach your drives, if the system is stable continue to add you PCI cards until you hit the problem again. This will be the incompatible or faulty card.
This procedure should allow you to find the component that's causing your bus timing fault.
I hope this will help you diagnose your hardware.
Spare head 2
Jan 06, 2008 | Mercury P4VM800M7 Motherboard
HP Officejet v40
Uninstall first and restart the pc!
INTALL again but change the directory or use WINXP ORIGINAL CD to repair OS
Oct 24, 2007 | Office Equipment & Supplies
Acer Aspire 3680 Laptop Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
