Question about Refrigerators
Kenmore bottom freezer will not defrost
Kenmore model 596.7182101 bottom refrigerator freezer keeps icing up. What do I do?
    Champion:
  • 363 Answers
I would check the Freezer Fan as the main point. This fan is very hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and frig. The minimum cost for labor and parts is around $300.00
Posted on Aug 02, 2009
Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore bottom freezer refrigerator keeps icing up how do i defrost it? model # 596.7182101
Sounds like the circulating fan is wearing out, this problem is very hard to diagnose because the fan still spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. The minimum cost for labor and material is around $300.00
Aug 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Mar 26, 2009 | Kenmore 53342 / 53344 Side by Side...
Error Code Er FF
Replace the defrost heater and defrost thermostat in the freezer.
Mar 23, 2009 | Kenmore Refrigerators
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer not defrosting
Hello pumpguy2
Welcome
You said, you have a Kenmore bottom Freezer Model 596.73503201. It works fine but the freezer has stopped defrosting. Any suggestions?
It is supposed to be auto or self defrosting.
What do you mean you are getting ice forming in the freezer?
Waiting for your response and more detailed explanation.
Huuum
Oct 01, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
