Question about Verbatim Electronics - Others
I bought Verbatim ''White inkjet printable'' dvd disks. How does one load them into a printer, and which printers can use them?
  • 476 Answers
You will need a printer with a cd tray that holds on to the disk while its printing,
My print tray moves backwards and forwards past the printer head as it applies micro dots of ink to build a finished image,
I have a Cannon i8 65,prints straight onto the surface of the disk,awesome photo quality prints on the disk,
Versatile with print various formats and media types too,Glossy,Matte,DVD,CDs,etc
Great prints and a sturdy machine too...
Hope this helps,MISTERDJ
Posted on Aug 02, 2009
Verbatim CD-R 52X Printable disc. What does the term ' Silver Inkjet Printable" mean and how do I use it. Thank you.
> silver inkjet printable
It means that in addition to the "bottom" of the disk being capable of being "burned" by a CD/DVD writer, that the "top" of the disk is capable of absorbing ink, if you put the disk (instead of a sheet of paper) through an inkjet printer, and print some images/text onto the surface, to create a professional-looking label on your disk.
Oct 19, 2010 | Computers & Internet
Ink won't dry on lightscribe
You need special absorbent coating on the printable DVD's if they are suitable for that. Are you sure you can print on the sort you have usually they are all white. It also must actually say suitable for PC printed labels etc too.
Jun 18, 2010 | Verbatim (95058) 25 Pack 16x DVD-R Storage...
What dvd's do I need to down lad picture's on
To print images or labels on a CD or DVD using a printer with a CD/DVD printer function, purchase CD/DVD disks that have a white matt printable surface.
Dec 14, 2009 | Dell Computers & Internet
Printing on Verbatim DVD-R Discs using a Rimage Prism Plus Printe
Most likely is is just a dirty printhead and rollers.
John Norman Max Optical LLC. john@maxoptical.com 610-269-7033
Sep 30, 2009 | Rimage Prism Plus Thermal Label Printer
Epson Stylus R220 CD Print Smears after printing.
It has to be a bad batch or the wrong system.
Are you sure that the disks are labeled inkjet printable and not lightscribe?
Most printables are white in color and lightscribes are tannish.
Jun 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Canon pixma 4500
HI
FIRST YOU HAVE TO MAKE SURE YOU HAVE PURCHASED THE CORRECT WHIT PRINTABLE DISKS.
YOUR PRINTER WOULD HAVE CAME WITH THE NECESSARY SFTWARE CALLED CD PRINT.
OPEN THE PROGRAM AND FOLLOW THE INSTRUCTIONS TO CREATE THE IMMAGE ON THE CD/DVD.
YOU WILL BE WORKING WITH AN IMAGE OF A BLANK WHITE DISK, AND WHAT EVER YOU DO THERE WILL BE PRINTED ON YOUR REAL DISK.
YOUR CANNON PRINTER WILL HAVE AN OPENING IN FRONT WHERE YOU WILL HAVE TO INSERT THE DISK WITH THE PROVIDED TRAY ( A BLACK RECTANGLE WHICH THE CD/DVD WILL FIT ON).
FOLLOW THE INSTRUCTIONS ON THE PC AND YOU CANNOT GO WRONG
Jan 08, 2009 | Canon Pixma iP4500 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon mp 600r dvd printing
IT is easy once you have done it...it works a treat  but you do have to check all the correct boxes. (1) use cd label print that comes with the mp 600 ( i have a 600 not a 600 r)  design the label and then hit print (2) in paper size choose (cd r tray F ) (3) under the paper size box  choose (quality and media) (4) in media type choose ( printable disk recomended) (5) in paper source choose (disk tray) (6) hit print
make sure you have the cd loaded in the disk tray ready with the arrows lined up
good luck
Mar 25, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Electronics - Others Logo
182 people viewed this question
Top Verbatim Electronics - Others Experts
Stu Ungar
Are you a Verbatim Electronics - Other Expert? Answer questions, earn points and help others
