Televison & Video Logo
Posted on Aug 02, 2009
Need to ask about the remote, lost booklet. While
Need to ask about the remote, lost booklet. While you are programing it where is the enter button
Anonymous
Level 1:
  • Contributor 17 Answers
  • Posted on Aug 02, 2009
Anonymous
Contributor
Level 1:
Answers
17
Questions
0
Helped
8495
Points
67
It depends on which model you have. This is the website with their manuals:
http://www.memorex.com/search_results.php?product_category=55&product_family=62&family=50012
If you don't see your model, you can look to see if one of the others has a similiar remote.
1helpful
I have a dynex dvd player, I'm trying to program a universal remote to it...I don't have the code to enter into the remote
I have heard that Emerson remote codes work on that brand. if you have a booklet use those codes. if you dont have the booklet, try these codes - 003, 013, 012, 030, 046, 050, 051, 049, 077. Still no luck? try this site - http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV310 I have noticed codes tend to be the same across multiple remote makers so it may help you. Lastly, if all else fails, just google your remotes maker and go to there site and look up the manual program option. with it you just hit the power button until it works!
1helpful
Hello i lost the remote control booklet and i need the code for an rca tv. i have the gray 4.00 remote control ge/ jc022 the number on the inside is rc24914-d 3852
Use the Built in Code Search and never look for a code again!!!
  • 1 Turn on the device (e.g. TV, VCR or DVD) for which you wish to program.
  • 2 Press and hold the "Setup" button in the middle of the remote, under the "On/Off" button. Hold the button until the indicator light on the top left corner of the remote lights, then release the button.
  • 3 Press and release the button with the label of the device you wish to program. The indicator light will blink before remaining lit.
  • 4 Point the remote towards the device. Press and release the "On/Off" button every two seconds until your device turns off. (You may need to press the "On/Off" button up to 250 times before the correct code is found.)
  • 5 Press the "Enter" button on the lower right side of the remote control when your device turns off. The indicator light will subsequently turn off.
  • 0helpful
    Need to program cable remote (att) to tv ( SK-32H640G) do i need a code?
    You can do it one of two ways, you can enter a code, (for a Westinghouse TV, normally use the Sony codes) or you can scan for channels. To scan you can normally enter a code sequence which will come in your booklet when you install ATT, you will need to enter the code sequence and scan using channel up until your TV turns off. One the TV is turned off, you will need to press the TV button on your remote and your TV is now programmed. For more information or if you need live help please send me an email to [email protected]
    Purchased this remote for my mother and lost instruction booklet
    if(!numads) var numads = 0; adsense_ads = []; adsense_ads['ad02'] = new adsenseObject(1,false,false); google_ad_client = 'pub-1549962111268759'; // substitute your client_id (pub-#) google_ad_channel = '4183915953, 0288476200'; google_ad_output = 'js'; google_max_num_ads = '1'; google_hints = googAds.hints; google_ad_type = 'text'; //google_image_size = '728x90'; google_feedback = 'on'; google_adtest = 'off'; google_skip = numads; numads = numads + 1; google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Start by turning on the device that you want to program. (1) Press & release the device button that you want to program, lets say "VCR" LED will flase once (2) Press & hold the "CODE SEARCH" button until the LED stays on. (3) Press and release the POWER button. Point the remote at the device. (4)The LED will flash as the remote is searching for the code. (5) As soon as the device turns off press and release the "ENTER" button. The remote should NOW be programed.
    Lost RCA Universal Remote booklet for model RCR312W remote.
    you need to supply the SONY TV model just do a google of any URC booklet and then look uo the ctrl codes for your TV it has little to do with the brand of the remote
    please rate our help to keep service online
    2answers
    How do we code a remote for a magnvox 27
    Is it Comcast? With our cable box came an instruction booklet with codes for different brands. We tried two or three before finding the right one.
    I can't find the instruction booklet we had, but you might find one on your cable company's website.
    Lost booklet
    link to codes is at bottom
    Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
    Programming with Code Search
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
    3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
    4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
    The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
    Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
    Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
    http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
    Hope this helps you out, good luck.
    Remote control CODES
    HOW TO PROGRAM GE JASRM24912 Remote Control DOING CODE SEARCH
    1. turn on device 2. press setup (underneath on/off) till red light stays on then take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code.
    Hope this works for you
    Rca remote control
    I can't afford your price so I'll look somewhere else.
    Top Memorex Televison & Video Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
