Question about NetGear WGR614 Wireless Router
Says connection is excellent but i cant browse ..when i restart my modem and my router the internet works for about a min and then it stops again.
    Problem Solver:
  • 16 Answers
Contact your cable or dsl company and have them check to see if your modem is working correctly. If the modem goes up and down it will change the ip address and then your router will have to be restarted in order for you go get to the internet. If you want to rule out the router plug in a differnt one and if the problem persists I would say it is the modem.
Posted on Aug 02, 2009
My netgear wn2000 says its connected & has excellent receptionall bars are filled wht. still cant get internet.all my electronics need good reception to get the best out of them.help
First call your ISP and make sure your acct is update ($$$) sometimes they disconnect if something is wrong with your acct. Also they will help you to resolve any issues. Finally get here again!
Dec 29, 2014 | NetGear Computers & Internet
Can't get to internet. says i'm hooked to internet but cant go any where.
Check the lights on your modem and make sure that it is connecting. If it is, power off the modem (unplug it normaly) and the router (same unplug). Now wait a few mins, power the modem back on first and wait for all the lights to turn green (some cable modem will have a yellow light). Now plug in the router and wait for all its lights to come on. Now try the internet again. If this fails disconnect the router from the modem (ethernet cable) and plug your computer directly into it. Restart the modem as you did before and when all the lights are on, try internet again. If you have internet at this point the problem is in the router somwere, if not call your internet service provider.
Jul 21, 2011 | Computers & Internet
D-Link wireless router has been greta, until yesterday- the Roku boxes say my router strength is excellant, but all of a sudden, the box can no loger connect to the Internet even when I select my router-...
The router most likely is not synced properly with the modem. Your computer might still have a strong connection to the router, but isn't getting an IP address. Power everything down, including the modem and restart in this order:
1. Modem - allow a minute for it to run thru its diagnostics 2. Router 3. Computer
Once you've done this, if you're ISP isn't having outages, you should have the internet working again on your computer. If this doesn't work, call your provider.
Jun 19, 2011 | D-Link DIR-615 Wireless Router
Hello, I have Dell Inspiron 1525 Laptop and wireless Internet doesn't connect. I see the wifi light is ON and I see in Internet connection it shows my profile as connected. But if i browse internet does...
Please connect your computer directly to your DSL / Cable modem and check if your internet is working fine, if not turn off your modem and restart after a minute or two.
Now check again if the internet is working by directly connecting your laptop to your modem. if it is not working, contact ISP. if it is working, turn on your router and check if your wireless connection is working.
If you wireless connection is still not working, please check if you have plugged the modem to the internet / WAN port behind your router.
Also try logging to your router page (refer to manual for procedure) and try changing the wireless channel.
Dec 24, 2010 | Dell Inspiron 1525 Laptop
I just moved into a new apartment and I am currently attempting to use the same linksys router that I used at my old place (without difficulity). My lap top in the bottom right corner displays...
> excellent connectivity
This refers to the wireless connection between your computer & your router, not to the connection from your cable-modem (or DSL-modem) out through your ISP to the Internet.
If you use an Ethernet cable to connect your computer directly to the cable/DSL modem, do you still have "intermittent" problems?
If so, then your router (or other wireless devices, such as your neighbours' router, or your neighbours' wireless telephones that are trying to operate on the same broadcast frequency) is the problem.
Aug 21, 2010 | Linksys Wireless-G WRT54GS Router...
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
There is an Excellent signal but it's not connecting
That´s because of the ip assignment you have to set the ip of the router in the same net work ip scale of you modem that connects you to your isp example if ip modem is 192.168.0.10 then the ip you must set on the wan port mustbe 192.168.0.100, also check that you are connecting the out of the modem to the wanport on the wireless router.
Hope it helps
Jun 25, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Everything appears to be working, but not internet connection
Turn off the firewall in both the router and the modem. try again-- once it is working ...just turn one of them back on..
May 16, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Connected to internet but cannot browse.
hi there ;
there is no such solution for ur problem ..... the only solution is to firstly reset the router for 30 seconds and then upgrade the firmware of the router ..... remove the powercord for 10 seconds ...
> Again redo the settings then ....
Nov 14, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
93 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
