Question about Denon DRA-397
Can't unlock panel
After unplugging my receiver says, "panel locked". How do I unlock it?
  • 163 Answers
Hold the "Speaker B" button and the "Mode" buttons. Turn power on.
Posted on Aug 03, 2009
  • moog23 Oct 21, 2010
    This worked for me. I even called Denon but the didn't bother to tell me about this method.Instead they referred me to a Denon repair shop (surprise!) nearby that wanted to charge me $50 just to look at it. Thanks much for your suggestion.
  • James Van Houten II May 05, 2013
    Yes! It worked! Thanks.
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
Mar 07, 2018 | Whirlpool Washing Machines
Where is the keyless remote receiver on a 2008 srx
Remote control door lock receiver (RCDLR)
The remote control door lock receiver (RCDLR) is a multifunction module that operates both the keyless entry system as well as the TPM system. When an RF message is received from a keyless entry transmitter, the RCDLR interprets this signal and will request via serial data that the body control module (BCM) perform the specific function, i.e. door lock, door unlock, or vehicle locate.
Remote Control Door Lock Receiver (RCDLR)
In the right rear quarter panel behind the interior trim panel
Jan 23, 2018 | Cars & Trucks
Maytag dryer control is locked. how do I unlock it?
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light goes out when the control panel is unlocked. Also try unplugging it for five minutes to allow it to reset
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Jan 12, 2018 | Maytag Washing Machines
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    How to unlock controled lock
    There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
    Sometimes the problem is due to an electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
    Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    When I press the mode button on the front of the receiver to switch to dual mode nothing happens. What could be wrong?
    You have a bad receiver it sounds like. Try unplugging it from the wall electric source a few minutes and try again. If still unable to you will need a new receiver.
    Thanks for using Fix Ya.
    Jan 28, 2010 | DISH Network ViP622 DVR DTV Receiver /...
    Denon reeiver says control panel locked
    make sure power is off then hold spk B and mode buttons at same time while you power up system.
    Apr 04, 2009 | Denon AVR-1705 Receiver
    Front loader washing machine won't unlock door
    Remove three screw at bottom of washer, pull of lower panel, reach up on right side just under the locking mechanism and bull ring down. door should unlock.
    Jun 08, 2008 | Washing Machines
    Denon DRA-397 Logo
    405 people viewed this question
    Top Denon Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
