Tub wont spin to ring clothes out. belt may be broke?
  • briscoec May 11, 2010
    If you hear the motor running the belt probably is broken. Don't hear the motro, something else.
    Scholar:
  • 51 Answers
It would be of great help if you would have mentioned the name and model of your washing machine. In the case you have mentioned there several type of fix to this problem. One of these tips is to test the lid switch first.
Test the switch for continuity using a multi tester. Set the multicenter to the ohms setting X1. Place a probe on each terminal. The multi tester should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse; you can visually inspect the fuse or test it for continuity with a multi tester. If the fuse is bad, replace it with one of the same rating.
The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine.
Test the timer control
Test the centrifugal switch
Test the water level switch
Inspect the motor coupler
Inspect the driver belt (belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
Thank You for using Fixya.com
Posted on Aug 02, 2009
I have a GE Adoration WHDRE526E1WW top load washer. It drains and hits spin but will not spin. Lid switch seems to work. When tested the motor kicks on but will not turn the tub. Few times I manually spun...
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
Aug 13, 2017 | General Electric Washing Machines
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Motor runs, but clothes tub will not spin, what is the problem? There is a vynyl looling inch belt on the tub.....tub spins freely with hand control.
either the belt slipped out of the idler pulley or the belt itself broke,, click on this link for easy instructions for your machine http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm please take a moment to rate my response Thanks good luck
May 30, 2011 | Whirlpool LER4634J Electric Dryer
Spin cycle is not getting clothes completely dry, can still hand ring water from clothing
When the clothes are wet at the end of a cycle, check these: Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 01, 2010 | Maytag Washing Machines
Wont spin
worth repairing, can likely do yourself. check the lid switch, it is probably your problem. comes complete with wires that plug in. easy fix.
Nov 08, 2009 | Kenmore Washing Machines
Wont engage to spin mode
most likely a broken washer tub drive belt or coupler.
Oct 30, 2009 | Roper RAS6233KQ Top Load Washer
Grease oil ring around tub and it smells like oil?
The only place there is oil in a washer is inside the transmission. If you have oil in the tub (and it didn't come from the clothes you put in) you have a bad transmission seal. It is generally cost prohivitive to replace the transmission. It's time to get a new washer. Look into the front load machines which use much less water and spin out twice as fast as top loaders. Some even have direct drive, which means no belt, transmission, or clutch.
Jul 19, 2009 | Washing Machines
WFMC 3200 WONT SPIN OR WASH
Open machine's rear panel and look for a broken belt and does the motor spins. Let me know with your results and we will see how could we assist you.
Aug 21, 2007 | Bosch WFMC 3200 Front Load Washer
Washer
Coleen, you can get a visual on the belt by removing the two bottom screws on the front panel and pulling down a little on it and pulling it out from the bottom. There will be two clips that hold it on the top. Make sure your lid switch is operative first of all. After you have the front panel off, put it into spin and see what happens. If the belt seems to be o.k., there could be other problems. One of them would be the transmission itself. You do have a five year warranty on the trans..parts only. You could have something in the pump which would cause the motor to bind and not turn the trans. Or you could have something between the basket and tub causing your problem. Truley hope this helps..
May 22, 2006 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
