Question about LaCie (300740) 160 GB Hard Drive
Lacie D2 Hard Drive Power Loss (2)
Drive no longer starts up. The transformer box is making a faint electrical clicking noise, with the green power indicator flickering in time with it...
Short circuit perhaps? or blown fuse...? There is also a slightly white-ish powder around the 4 pin plug that connects directly into the back of the drive... (similar to the stuff that comes out of a battery when it knackers itself...)
I can't work out if the problem is internal to the drive or with the power supply (which would be fairly easy to replace)... Any ideas?
  • 60 Answers
Yep, its shorted out, just buy a new power unit.
Posted on Aug 02, 2009
  • JudeGraySmit Jul 26, 2011
    I had a failure on my LaCie 250gb external hard drive . Went to bed one night unit was working. Switched all my PC and accessories off. Next morning NOTHING from the LaCie unit. No green or orange light appeared. I bought an IOMAX adaptor on Amazon for £17 to check if it was a power supply problem (as I read here it was likely).This saved me money as a new power unit was over £40. I dismantled the LaCie unit to expose the IDE hard drive inside, plugged in this adapter and it powered up immediatly. Selection of 'plugs' on this adapter as can be used on SATA, ATA, IDE and 2.5 and 3.5 sizes are covered. I have now used on all my old hard drives to transfer data once thought 'lost'.
Drive stopped responding -- problem with power supply or drive?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 05, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie d2 Quadra 750gb HD, making werring,clicking noise.
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
May 13, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Same clicking Problem
Glad you worked it out cheap switch mode supplies can make a clicking noise when pooched. Now if the hard drive itself makes that noise you are in trouble. Almost any replacement power supply will do so long as it is capable of delivering not only the correct voltage but the correct current as rated in "mA" milliamps or "A" Amps.
You can of course exceed the current rating and quite often that can be a good thing to do as it may well prolong the life of the supply even if it may cost a few pennies more.
I can usually judge a good supply by its size and weight VS its power ratings. I like em large and heavy
Aug 11, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Fan keeps going, blue light always on, clicking noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Jun 28, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie d2 external drive
you may need to get a new driver for that lacie from their website..
support downloads, model o/s
Mar 01, 2008 | Computers & Internet
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie Drive making awful noise!
Lacie D2 drives in my experience are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a blue light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. If the drive is grinding like you say, most likely the disk is physically damaged. If this is something you experience often, maybe you should consider power conditioners. if the drive is being moved around alot, you should be gentle with it in transit. Drive enclosures, look rugged and have flashy lights and metal enclosures, but should be treated like babies. Drives are feircely sensitive. They should be padded, kept away from magnets, and treated like laptops. Hope this helps.
Sep 25, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Open Questions:
LaCie (300740) 160 GB Hard Drive Logo
340 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
