Question about Haier Heating & Cooling
My window air conditioner will not start. First time installed this season.
Make sure you have the correct line voltage at the plug.Some are 110 volt, some are 220 volt.
Here is the kicker...220 volt can be plugged into 110 volt plug at the wall with no damage.110 volt cannot be plugged into a 220volt socket at the wall without sustaining damage.
You can find out the required operating voltage of the a/c by reading the nameplate data printed on the a/c specs somewhere on the machine(not the housing}.
The plug end from the a/c should clue you into the proper machine voltage if you purchased a brand made in the USA.If it came from some third world country like Bangladesh, for example, the cheap bastards probably didn't wire the pigtail in at time of manufacture cause they are cheap ********.
You get what you pay for these days.
Call an electrician to chech it out.Don't be like the Bangladeshians!
Posted on Aug 02, 2009
How to replace coolant in air conditioner...
fan motor is bad stuck or relay or capictor if fan dont pull air thru condensor it does not turn to liquid and then wont evaporate or cool in evaporator
Aug 28, 2012 | Friedrich QuietMaster SM24L30...
Tip
Air Conditioning Tips & Tricks You Must Know!
  • Try setting your thermostat between 72°F and 78°F. Each degree setting below 78°F will increase your energy consumption by approximately 8%. As you can see, that can add up to a lot of money over a year.
  • Inspect and clean both the indoor and outdoor AC/Heating coils. The indoor coil in your air conditioner acts as a magnet for dust because it is constantly wetted during the cooling season. Dirt build-up on the indoor coil is the single most common cause of poor efficiency. The outdoor coil must also be checked periodically for dirt build-up and cleaned if necessary.
  • Check the refrigerant charge. The circulating fluid in your air conditioner is a special refrigerant gas that is put in when the system is installed. If the system is overcharged or undercharged with refrigerant, it will not work properly. You may need a service contractorto check the fluid and adjust it appropriately.
  • Use bath and kitchen fans sparsely when you are running the air conditioning system.
  • Reduce the cooling load by using cost-effective conservation measures. For example, effectively shade east and west windows. When possible, delay heat-generating activities, such as dishwashing or baking, until the evening on hot days.
  • Try to not use a dehumidifier at the same time your air conditioner is operating. The dehumidifier will increase the cooling load and force the air conditioner to work harder, which in turn increases your utility bill.
  • Over most of the cooling season, keep the house closed tight during the day. Don’t let in unwanted heat and humidity. If practical, ventilate at night either naturally or with fans.
Room Air Conditioning Units
  • The unit should be level when installed, so that the inside drainage system and other mechanisms operate efficiently. If possible, install the unit in a shaded spot on your home’s north or east side. Direct sunshine on the unit’s outdoor heat exchanger decreases efficiency by as much as 10%. You can plant trees and shrubs to shade the air conditioner, but do not block the airflow.
  • Set the fan speed on high, except on very humid days. When humidity is high, set the fan speed on low for more comfort. The low speed on humid days will cool your home better and will remove more moisture from the air because of slower air movement through the cooling equipment. Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing electricity use.
  • Set your air conditioner’s thermostat as high as comfortably possible in the summer. The less difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be. And don’t set your thermostat at a slighter setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Don’t place lamps or televisions near your air-conditioner’s thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
Proper maintenance of your air conditioner will also save energy. Be sure to do the following:
  • At the start of each cooling season, inspect the seal between the air conditioner and the window frame to ensure it makes contact with the unit’s metal case. Moisture can damage this seal, allowing cool air to escape from your house.
  • Check your unit’s air filter once a month and clean or replace filters as necessary. Keeping the filter clean can lower your air conditioner’s energy consumption by 5% to 15%.
  • Occasionally pass a stiff wire through the unit’s drain channels. Clogged drain channels prevent a unit from reducing humidity, and the resulting excess moisture may discolor walls or carpet.
  • *In the winter, either cover your room air conditioner or remove and store it.
on Aug 19, 2010 | Heating & Cooling
I have a GE AGMO8LJG1 window air conditioner. Just put it back in the window for the season. The motor runs, but no air comes through. What do you think is wrong?
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 16, 2011 | GE AGQ10AJ Wall/Window Air Conditioner
Water not draining from unit. Drain pipe is dry outside but doesn't appear to be blocked?
I think your a/c is Room (window)air conditioner.
Normally, in window a/c the water gets evaporated with condenser heat. During winter season or on less ambient temp, the water flow will be there.
Dec 27, 2010 | DeLonghi Heating & Cooling
Lg lwhd1200fr air conditioner is leaking water inside, best ideas on how to solve this problem?
REPOSITION UR WINDOW AC. RAISE FROM FRONT ABOUT 1/2 " SO WATER WILL DRAING DOWN TO CONDENSER OUTSIDE.
Sep 12, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
Squeaking sound
are taking about the out side fan if so you can oil them
Jun 28, 2009 | Goldstar KG6000R Window Air Conditioner
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Starting unit for first time of season
8 Hours should allow the oil in the system to resettle. Then you can restart or place it in operation. They should be stored on the base.
Jun 08, 2008 | Haier HWR06XC5 Wall/Window Air Conditioner
When turned on, the unit sounds like it will start then turns off within a minute.
Presently according to my information there is no recalls for Fedders products at this time for this model type.
May 27, 2008 | Fedders A&B Chassis A1A07W2B Air...
Heating & Cooling Logo
88 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
