Question about Tomtom GO GPS Receiver
Yes i just bought a tomtom navigation system someone at the store said it has to be charged 24 hours I have the cigarette lighter charger in it will this charge it up?
    Scholar:
  • 32 Answers
Yes, It will charge the unit but I would leave it plugged in for about 2 days if you are going to use it when it powers up. I plugged mine in immediately after purchase and used it about 20 min later. the battery should read full charge after a day or two with continued use. Enjoy it!!
Posted on Aug 02, 2009
My tomtom go 510 will not charge in car but ok at home
The Car chargers are generally the defective unit.
I have also faced a similar issue as the spring loaded cigarette lighter was pushing the charger causing it to disconnect.
Jul 31, 2016 | Tomtom GPS
Can i use tomtom in 1996 ford mondeo cigarette lighter
So long as it is a 12 volt negative ground system then yes. Plug ins are designed for cigarrette lighters in cars.
Nov 24, 2013 | Tomtom GPS
Unlocking the car
You can either buy or easily make from readily accessible parts the "battery clips/clamps to cigarette lighter adapter" or just get a cheap chinese battery charger that has the cigarette lighter thing already attached to it. Plug one of these into the cigarette lighter for at least a few hours and it will charge the battery at least enough to unlock doors, etc.
If you are in some kind of metro area go to the Harbor Freight store and for under $15 you'll be OK. It is likely not the alarm system from preventing the hood being opened, but the lack of any electric power to kick the linear actuator from closed to open. Even still, once the battery is charged up again the alarm system would now be functional and you'd be able to turn it off or maybe put it in stand-by mode.
Nov 17, 2017 | 1988-1989 911 Carrera Relay Alarm
I just bought a garim nuvi 1360 and i forgot to ask how to charge the unit . first to plug it in the car lighter, what about the usb, could i tapp it in my laptop thru usb. pls explain better oscar...
There are 3 ways to charge your satnav. You can charge it with the car cigarette lighter socket or an optional mains charger both of which take around 4 hours. You can charge it through the USB port of your computer which takes about 8 hours. If charging with the computer both the satnav and computer should be turned on.
If charging with the car be sure that there's power going to the cigarette lighter socket. Some cars need to be running for power to reach it.
Jul 12, 2011 | GPS
How do I charge it for the first time?
You can charge it by connecting to your cigarette lighter socket in the car for 4 hours, or you can charge it with a mains charger for 4 hours. The mains charger normally has to be bought seperately. Or you can charge it by connecting it to your computer for 8 hours with a mini SD card.
Mar 26, 2011 | Garmin nuvi 1450 GPS Receiver
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
TomTom GO 910 won't turn on.
Two possibilities:
- if someone has used the wrong charger, and connected it to a 12V supply, the mainboard may be damaged. In that case, you need a replacement.
- the battery may be discharged. Even if the green light is on, it doesn't necessarily charge up. Try pushing it hard onto the mount for a few minutes, then see if it will turn on.
Feb 08, 2010 | Tomtom GO 910
How can I open the luggage compartment of a Porsche 911 when the battery is dead?
The best way to do this is to put battery voltage back into the system through the cigarette lighter. You can buy a battery charger at an auto parts store or walmart that is designed to charge the battery through the cigarette lighter. It will have a plug on it that insert right into the cigarette lighter. Let it charge a little, and try the button again. It will pop right open.
Feb 02, 2010 | 2005 Porsche 911
Dead
Does the cigarette lighter work in the car when you press it in? Does it get hot? If not has the fuse blown for the cigarette lighter?
If that is supplying power you may have a fault in the cigarette lighter to Tom Tom lead. Carefully check the fuse (one of the six bumps) in the plug and make sure it is still intact (use a meter).
If the fuse is OK then the lead itself may be faulty and probably needs to be replaced.
HTH
Peter
Jan 26, 2009 | Tomtom ONE GPS Receiver
Can i plug my tomtom 1 xL in to a 24v cigerate plug
Hello callan_1,
The USB car charger which TomTom makes for the One XL GPS receiver appears to support cigarette lighters with voltage from 12 to 24 volts. If you have this charger you should be able to use it power your GPS.
Best Regards,
Ken
"Go Ahead Use Us."
Jun 24, 2008 | GPS
Tomtom GO GPS Receiver Logo
146 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
