Question about LG Goldstar GWHD5000 wall/window Air Conditioner
My a/c shut off and won't turn back on. we checked the switch and the breaker, nothing is wrong with them. what could be wrong with it. Can it be fixed?
Money can fix everything in life.
You can't get impatient with a/conditioners.
Put the a/c to cooling, make sure the set temp is below the indoor air temp(not just one degree either...way down) and give it 5 to 15 minutes.
There are anticycling devices (safeties on modern a/conditioners) that prevent them from burning up.
You'll never mentioned if you are in house or a commercial building(at work).Commercial building stats may be off ine on a built in timer.
Posted on Aug 02, 2009
We have a Nordyne AC/Heater model # E2EB-012HA. My problem with the unit is that the heater will not turn off and the blower motor also won't turn off unless we switch the breaker to off. Also I...
my nordyne e2eb-012ha after running shuts off most of the time we have to reset the element breaker to get it going again. any ideas can"t find directions to how to get behind breakers thanks morris
Nov 28, 2012 | Heating & Cooling
15 amp cutler hammer branch feeder type AFCI triped off and will not turn back on. I have tried switching off for 10sec and then back on and still nothing. Also, the test button will not do anything. The...
if the breaker has tripped the test button won't do anything ,, for the breaker to trip something down stream of it is causing this to happen,, check all the switches and or receptacles in the circuit that are controlled by this breaker, 3 types of line problems cause tripping,, ground to line, Line to line, and line to neutral. in this ,, also consider that extension cords, faulty appliances , ( lamps, radios, anything plugged in with a feedback short ) will cause the breaker to trip. even a nail to hang a picture that pierced the wire can cause this, add to that , a AFCI breaker will trip much more easily than one thats not, or even a GFI breaker, , try this, if you have the knowledge to do electrical work in a panel, if not get someone who is, switch the tripping breaker with another one of the same value, ( in this case 15 amp) see if the one you put in place of the one thats giving you problems trips. If it doesn't, you have a weak or bad breaker, so just replace that one, if it does, your going to have to trace out that entire circuit to find the reason for the feed back into the panel
Oct 07, 2011 | Electrical Supplies
Washer won't turn on
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 18, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
The Power won't turn on.
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB, motor.
John C
Sep 11, 2011 | Washing Machines
My dryer shut off in the middle of a cycle and now won't turn back on. What could be wrong with it? I have checked all my breakers so its not a problem with my electric.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 19, 2011 | Kenmore Dryers
Washer won't start
From your comment 'washer won't start' I am assuming that there is no power indication i.e. no lights/LED's?
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
John C
Jul 09, 2011 | Washing Machines
Plug the new fan motor, nothing
Sounds as if the Fan Switch may also be faulty. Or the new fan motor is defective. Is the flame function on the electric fireplace working? If the flame function is working, than obviously the fault is either in the fan switch or the new fan motor.
If the motor has a regular receptacle type plug on the end of the cord, try plugging it directly to a wall outlet and see if it works. If you're able to do that, then the problem is in the fireplace's fan switch or in the wiring circuitry going to the fan motor. Perhaps, this is what was wrong all along and not the fan motor, itself.
If nothing is working, check the wall receptacle that the fireplace is plugged into, by plugging in an electric lamp. If the lamp won't turn on, then there's a circuit breaker tripped in your homes circuit breaker panel. Check the circuit breaker panel for a tripped breaker and with nothing plugged into the offending receptacle, reset the breaker. Plug the fireplace back into the receptacle, turn it on and see if it trips the circuit breaker. If it does, there's an electrical short some where in the fireplace. Look for burned or frayed wiring, as well as bad connections.
Hope this helps solve your problem.
Feb 15, 2011 | Dimplex DF3003 Electric MidSize Heater
Power turns on but nothing else turns on, just the display screen. is there an easy fix ie fuse or something?
CHECK BREAKER AT MAIN BOX , SHUT OFF BREAKER ALL THE WAY OFF AND BACK ON. IF YOU DO NOT HAVE BLOWER WHEN YOU TURN FAN SWITCH TO ON THEN YOU STIIL HAVE NO POWER TO UNIT . GO TO OUT SIDE UNIT ON GROUND AND PULL OUT DISCONNECT FUSES AND TEST THEM OUT OF FUSE HOLDER LIKE AUTO FUSES. IF UNIT IS ON ROOF SHOULD HAVE FUSES UP ON ROOF IN 6  X4 GRAY BOX. SHUT OFF BREAKER FIRST BEFORE FUSE TEST. IF FUSES OK AND BREAKER OK THAN YOU MIGHT HAVE BLOWN TRANSFORMER.
Apr 21, 2010 | Danby DAC9003D Air Conditioner
Ac unit wont start
Sounds like a classic case of a burnt/pitted compressor contactor. The contacts can get pitted and sometimes burnt. This can cause them to stick and the unit will not shut off unless you shut off the circuit breaker. When you shut off the circuit breaker, the contacts would have cooled down which could have led to the problem you are now experiencing......will not come on. Open up the electrical box. Look near the bottom for a brown or black part with the wires from your circuit breaker wired directly to it. This is your contactor. In the center is the piece that moves up and down to allow the electricity to go to your compressor and fan motor when there is a call for cooling. Check to see if it looks burnt or otherwise damaged.
Apr 04, 2010 | Carrier 38CKC048 Air Conditioner
Pushmatic breaker keeps tripping everytime I hit
You have it shorted out somewhere along the line. If it is a light switch you are switching, what have you done lately to make this trip? Anything? You might have a bad breaker. You can check it by shutting off the power, pull the wire out of the tripping breaker, put it in another breaker, turn the power back on, switch the breaker on, then hit the switch and see what happens. If it snaps off, it is not the breaker, but the switch, the wires in the box, or the lights, or something along the line, you will have to check each one. New construction has made all lights and all receptacles separate, so if your house is old, you might be looking at receptacles too. Check anything plugged in to an outlet, make sure there is nothing shorting. Hope this helps.
Apr 03, 2010 | RTO Pushmatic 100Amp 2-pole circuit...
LG Goldstar GWHD5000 wall/window Air Conditioner Logo
251 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
