Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
My nephew has a Hayward H100ID1 pool heaterThe problem is
My nephew has a Hayward H100ID1 The problem is somtimes when you turn the t-stat on it fires and works fine.Other times it will fire and then when it calls for heat again you'll hear the click and then it will not fire. I did a continuity test on the t-stat and it seemed fine. Could it be the ignition module. Any help would greatly be appreciated. Thanks in advance. PS: I should mention I'm a retired NYS License#223 electrician.
I changed the ignition module. It has been working fine since.
Posted on Aug 02, 2009
I need to know what hold the thermastat in place in the heat exchanger?
In many heaters, nothing does, it just inserts into the tube in the exchanger. The t-stat does not come in direct contact with the water.
Aug 17, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I have a Hayward H100ID1 heater. I turn the gas shut off on and I know there is gas going into the heater. But when I turn the heater on and it sparks, the is no gas smell and it does not light. What can...
first be sure your water filter is clean and the pressure gauge works.....you may need to bleed the gas line to get fresh gas to the unit, you can use soapy water to check, that the fitting leak free, after bleeding at the block
Jun 04, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
How to winterize the h100id1 hayward pool heater
disconnect or blow out with air and antifreeze then pull freeze plugs and disconnect pressure switch and turn off gas
Sep 23, 2012 | Hayward 100,000 BTU Pool Heater H100ID1 -...
New h100id1 will not even fire up
if voltage to unit check transformer if ok check pressure switch if ok see if voltage to gas valve if ok bad gas valve if no voltage check safety circuit
May 11, 2012 | Hayward Pool & Spa
Make sure that you drain all of the water out of the pool heater to prevent damage during freezing weather. That is the most important thing you can do to winterize pool heaters. If you have a cover, you might want to use it to prevent weather related exposure, but as long as you have the water out, you will be ok.
Oct 29, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I purchased a used Hayward H100id1 pool heater and lost the instructions. How can I get a manual with install instructions and how to use it?
Here is a copy of the users manual for these pool heaters. It should have all of the installation info that you need.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Jul 04, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Open Questions:
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
285 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
