Question about Garden
No heating scout 135 northstar the sprayer works fine punps diesel through lines no fire what should i check first i could not find a reset button
I have a Titan 640i painter sprayer that is older . Made around 2002 . It will not run . The yellow light flashes but the motor doesn't start. The power source is fine. The pressure is turned up.
If the motor fails to start look for a button (often red) on the motor. This is a reset button for the thermal overload protection most electrical motors of significant horsepower are equipped. Make sure the power is off, push the button to reset, then power on the motor. If the motor still does not start check to see that the mator's shaft turns freely. If not, the mator's armature is frozen due to corrosion or melt down. If the armature turns but the motor still isn't starting, another possibility is that the motor's brushes are too worn or have cracked or fallen apart due to age and/heat. Motor brushes are fairly cheap and normally easy to replace. If you're not a handyman consider taking the motor to an electric motor repair shop to check for continuity and estimate for repair. Hope this helps!
Jun 13, 2016 | Titan 440 Impact Airless Paint Sprayer...
Where is the fuel pump reset button in the trunk?? I cannot find this anywhere
Are you sure your car has a fuel punp reset button in the trunk? Mine has not! Not all cars has fuel punp reset button in the trunk
Apr 25, 2015 | Cars & Trucks
I have a 1994 Kia sportage 4 x 4 with an R2 diesel engine. the tachometer works erratically. most often it does not work and while driving sometimes it works. i see two wire connections at the diesel...
there are two wire beside the injection pump,,,, i think face the injection punp it is leftside... that's the wire sensore to the tachometer
May 12, 2011 | 1995 Kia Sportage
Looking to replace triger (leaks)
NorthStar brand equipment comes from Northern Tool. You can't replace the trigger, but they sell the replacement spray wand here and it's only $11.99. There are other wands, some longer, etc. They are pretty universal -- you just slide them onto the hose and tighten the band clamp. Good luck! If this is helpful, please rate my answer, thanks!
Jun 02, 2010 | Northstar ATV Tree Sprayer 16 Gallon, 1...
2001 dodge 5.9 diesel Cranks for 20 to 30 sec to start in morning
You have fuel runback.Replace the injector leak off pipes then try.If this does not work then have a non return valve fitted to your fuel supply pipe close as possible to the punp.Hope that was helpfull good luck.
Aug 01, 2009 | 2001 Dodge Ram 2500 Truck
1993 Cadillac Eldorado overheating
I am assuming you have the Northstar engine.
Check for coolant flow at the Purge line,this is a common problem on the Northstar.
There is a small diameter hose coming from near the top of the coolant tank,this is the purge line.
With the engine idling,pull the purge line from the tank,if there is no coolant flow from this small hose,it is blocked and this will cause overheating.If the hose is clear, check for blockage at the nipple on the tank.
Are you running it without a thermostat? If so,then strangely enough,this will cause overheating as the Northstar cooling system is different to most conventional systems and therefore will not help you diagnose the problem.
May 29, 2009 | 1993 Cadillac Eldorado
No water passes from faucet to hand sprayer
try soaking it in some CLR calcium lime and rust remover .
Mar 15, 2009 | Kohler Model 10430: FortĀ® Single-control...
Dakota Scout kvm
I use one of these, and hotkey sequence is . Where is A,B,C or D.
Jan 02, 2007 | Dakota Scout KVM Switch
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
