SOURCE: Wont start
for starters sounds like you need a battery. I would have it checked. this can also be messing with the security system but you may have a problem with your passlock sensor in the switch. have battery tested and put a new one in it and lets go from there
SOURCE: 2001 chevy lumina wont start battery was charged
like dude said above me and possibly a bad battery.
SOURCE: Battery not charging message. Took battery to have
Most likely you have a bad alternator. The alternator maintains the the charging system. you have the option to remove the alternator and take it to the parts store and have it tested too!.
SOURCE: my explorer won't start, It
if the batter has a drain the starter may be at fault the starter can drain a battery with out running i would unhook the battery cables then charge the battery then i would have the starter tested.
