Question about RCA Televison & Video
TV is stuck in SAP mode
My TV sound is struck in SAP mode. The only channels that I can hear sound on is the ones broadcasting in SAP. I have tried everything. The sound button on the remote takes you to the sound menu, There are 5 options there one of them is SAP, I have repeatly hit the number 3 button for Stero but only hear static on the other channels other than SAP broadcast channels, which there are only 2 of them.
    Top Expert:
  • RCA Master
  • 75,025 Answers
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Aug 07, 2017
5 Suggested Answers
  • 979 Answers
SOURCE: cant turn sap off missing sound on some channels
Hmmm, you'll need that original, there. See if you can find one, and maybe even just borrow one to get what you're after...accordianman
Posted on Feb 09, 2008
  • 85 Answers
SOURCE: SAP turns on automatically on a few channels
maybe the switches of your tv are malfunction
Posted on Jun 03, 2008
SOURCE: Can't turn off SAP/MTS without remote
Dynatron MR 110 available at various sites including Amazon.
Posted on Jan 11, 2010
  • 3083 Answers
SOURCE: under the channel it says
I found this information in the manual, and perhaps it will help:
1 Switch the audio.
• Every time you press [AUDIO], the audio will
be switched as below.
MAIN : Outputs main-audio
SAP : Outputs second audio channel
MONO : Outputs mono-
Also the manual says this about SAP:
(Secondary Audio Program)
Second-audio channel delivered
separately from main-audio channel.
This audio channel is used as
an alternate in bilingual broadcasting.
Here is a link for the manual, in case you want to go over the settings. I'm thinking this is a setting problem in the menu, but it can be a physical problem with a cable line.
Of course it could also be a trickier problem, but check your settings, check the cable line with another TV if possible, and then contact ILO Support for help, in the event nothing fixes it.
Good luck, and hope this helps.
Posted on Dec 01, 2010
How to I disable the SAP function on RCA FLAT 19 INCH screen?
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
No sound,but good pic.everything else works fine.(toshiba 57hx94)
• Check the antenna/cable connections (see Chapter 2).
• The station may have broadcast difficulties. Try another channel.
• The sound may be muted. Press VOLUME.
• If you hear no sound, try setting the MTS feature to STEREO mode (page 81).
• Make sure the SPEAKERS function in the AUDIO SETUP menu is set correctly (page 83).
• If you are not receiving a second audio program from a known SAP source, make sure the MTS feature is
set to SAP mode (page 81).
• If you hear audio that seems "incorrect" for the program you are watching (such as music or a foreign
language), the SAP mode may be on. Set the MTS feature to STEREO mode (page 81).
• When using an external audio amplifier, if you connect the amplifier to the VAR. AUDIO OUT jacks, the
volume of the TV and amplifier must be set above 0 or you will not hear any sound (page 20).
Dec 03, 2010 | Toshiba 57HX94 57 in. HDTV Television
How do I get my rca truflat tv to get out of mono?
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
Tv has sound on all channels but one. Had sound but 30 min later no sound. When watching two tv's on same channel the one with no sound was lagging behind other tv not in sync as all other tv's in house...
Check to see if your audio source is set to SAP. This stands for secondary audio program. For example, some stations broadcast english and spanish. Some stations broadcast english and nothing. If you are on a channel that broadcasts english and nothing, and you are SAP setting, you will hear nothing.
Jul 03, 2010 | Sony KDF-E42A10 42 in. LCD Television
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
Sound goes out for certain programs or commercials on different channels, but not all of them
Check your tv's audio settings. If there is an "SAP" button on your remote try hitting that. It stands for secondary audio program. Most manufacturers put it near the corners of the remote leaving it prone to getting hit without knowing. Most shows are broadcast with a spanish version of the audio. Hitting that button should allow you to hear it, but some tv networks do not broadcast the SAP audio making it seem like there is no audio. It usually affects more than one channel, and commercials do not broadcast SAP either.
Jan 20, 2010 | JVC AV-56P575 56" Rear Projection...
your tv has audio setting called SAP that is for channels that are broadcasting on a second language like spanish, on the channels that do not have this SAP capabilitie you will not hear anything unless you put your tv on stereo mode, so you need to go out of the Sap mode by a button on the remote, check for mts, button , or audio thank you
Jun 21, 2009 | RCA R52WM24 52" HDTV Projection Television
I have an audio problem LC-26d43u
What's "everything"?? Have you looked at the audio menu to see if you were on SAP (second audio program).. Being in SAP could affect one or more channels that do not broadcast in SAP mode.
Nov 13, 2008 | Televison & Video
Tv audio feed
You most likely have the SAP mode activated. Look for a button on your remote or an item in the on-screen menus of your television called MTS or SAP. You want to set this to "Normal" or "Stereo" (or even "MONO") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you will hear other audio. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed.
Feb 14, 2008 | Televison & Video
Cant turn sap off missing sound on some channels
Feb 09, 2008 | Sharp 27H-S60 TV
Televison & Video Logo
322 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
