I've lost my "browse" capabilit. When I open PSP and the small square comes up in the middle of the screen it won't let me do the browse feature. The top of the box says: OPEN Look in (file name) (picture) (picture) File name ________________ OPEN CANCEL Files of type ____________ HELP BROWSE The "OPEN", "CANCEL", and "HELP" are in black; the "BROWSE" is in grey and I can't click on it or open it. I have tried everything, but in the process have lost many of my toolbar options. Before I lose everything, can anyone help me?
Quando avvio l'applicazione mi scrive"The file C\Windows\scrnrdr.exe. could not be opened.Please check that your disk is not full and that you have access to the destination directory.Accesso negato
Posted on Aug 03, 2009
I can't open some apps i.e. Walgreens without turning off private browsing. How do I turn that off?
On an Mac or Laptop
Close the Private Browsing window, switch to a different Safari window that isn't using Private Browsing, or choose File > New Window to open a window that doesn't use Private Browsing.
On an iPhone or iPad
Tap the "Safari" icon on the home screen to load the Safari browser. Swipe down on any Web page to display the address bar and navigation buttons. Tap the Panels icon in the bottom right corner of your screen. The Panels icon resembles two small overlapping squares. Tap "Private" to disable private browsing. The device will then prompt you to select whether you want to close or keep open existing Web pages.
Jul 26, 2016 | Computers & Internet
Group not pulling water
Remove the portafilter, screw, screen and diffuser in group, and if the water is still not coming out then it is blocked at the metering jet above the grouphead, you will see a small U shaped hose connected to a square box there. Metering jet is on the top of box under the fitting. Unplug machine turn of water. You will need a 14mm open end wrench in memory serves me right, it might be 17mm. Carefully remove U tube both ends. Then check the small orifice in the middle it might be covered by a small screen, try not to damage screen unless you have a replacement. If that is clear, we will look at the black box connected to the side of the square. That is your solenoid valve it might be blocked. Using 14mm wrench remove dischage, then nut, slide off black box. Notice where the silver long part connects to the brass, there is a big nut. You will need a crescent or a 24mm open end wrench. Remove slowly there is a plunger in there it only fits one way. Check the 2 holes in the brass piece make sure the middle is clear or turn water valve on and make sure water flies out of there, be careful it might have alot or pressure if not blocked.
Mar 28, 2014 | Nuova Simonelli Mac 2000 I Group Espresso...
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
I cannot get onto the internet I keep getting the mesage I am incognito
Incognito mode (browse in private) For times when you want to browse in stealth mode, Google Chrome offers the incognito browsing mode. Here's how the incognito mode works:
  • Webpages that you open and files downloaded while you are incognito aren't recorded in your browsing and download histories.
  • All new cookies are deleted after you close all incognito windows that you've opened.
  • Changes made to your Google Chrome bookmarks and general settings while in incognito mode are always saved.
Tip: If you're using Chrome OS, you can use the guest browsing feature as an alternative to incognito mode. When browsing as a guest, you can browse the web and download files as normal. Once you exit your guest session, all of your browsing information from the session is completely erased.
Also visit the link provided below :
https://support.google.com/chrome/bin/answer.py?hl=en&answer=95464&p=cpn_incognito
Jun 23, 2012 | Cell Phones
I just got this ds lite and when you touch the left side of the touch it shows you are touching the middle of the screen. This is the 2nd ds that gave me this problem.
try recalibrating your touch screen.
go to the screen with the clock and calendar.
at the very bottom of the touch screen is a DS icon, select it.
next you'll get a screen with: a wrench, clock/calendar, person,a cross hair with a small square in the middle.
select the the cross hair with a small square in the middle.
the DSLite will walk you through recalibrating your touch screen.
hope this helps :D
please rate solution
Dec 30, 2010 | Nintendo DS Lite Console
How to use internet on psp
Fully charge your PSP. Using WiFi requires a lot of battery power.
Verify that you have access to a router or HotSpot. If your router is password protected, then be sure you know what the password is. Be aware that some public WiFi access point are incompatible with the PSP.
Update your PSP's firmware to the most current version. Newer versions of the firmware have better Internet features than older versions.
Turn on the WiFi switch on your PSP. On older PSP models this switch is located on the left side of the device. On newer models, it is located on the top of the device.
Select the Internet icon from the PSP's main menu.
TO START BROWSING
Look at the screen once the browser loads. By default it will load the Sony webpage. You can set your own homepage later.
Use the analog stick to control the mouse cursor. The "X" button is equivalent to clicking the mouse.
Use the circle button to reject a choice or to disconnect from the Internet.
Press the triangle button to bring up the address bar at the top of the screen and the options bar at the bottom of the screen. Selecting the address bar, or any place on a webpage that requires text entry will automatically bring up the virtual keyboard screen from which text may be entered.
Choose the icons along the options bar at the bottom of the screen to change settings, set a new homepage or access other browser features such as browsing history, bookmarks or help. Tool tips will help you identify the features you are looking for.
Press ENTER to look up in Wiktionary or CTRL+ENTER to look up in Wikipedia
Sep 30, 2010 | Sony PSP-3000 Silver Console
Screen is blank with a small square in the middle
hello there:
try by restarting the computer and using the f8 key you need to go to the last known good configuration it should restore if not you will need to reinstall the windows program hope this helps you out sincerely D.Jones
Jun 06, 2010 | E-Machines M5405 Notebook
Back light does not work on board
All You Need To Do Is Press The Small Square On The Bottom Of The PsP
Feb 24, 2009 | Sony PlayStation Portable (PSP) Console
My Canon Rebel XTi lost its RAW capabilites, probably after downloading the last firmware update. I get the 6 Quality options, but not the RAW option.
I think the RAW is not available in the "Auto" option. The Instruction Manual doesn't mention this or the explaination of the RAW feature. Thank You.
Sep 18, 2008 | Cameras
Psp switch is broken
You should get it fixed. You can get it fixed on ebay.com just type in psp repair and you will see people who fix them.
May 31, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
David Payne
David Payne
