Question about Sharp Viewcam VL-NZ50U Mini DV Digital Camcorder
Sharp vl-nz50 the cam corder is not turn on the chrger is OK but no red light when charging the battary in the you have service manual for this cam?
  • 1 more comment
  • Anonymous Jan 17, 2008
    Cam completely dead. Does not charge the battery. Charger ok!
    Memory batt ok.
    Have tried to use external power directly on the batt-pins on cam but nothing works.
  • ccsicc May 27, 2008
    It just quit working for no reason. Will not power up, no display, nothing . . . NADA. I have charger so I know that batteries were charged. What a waste!
  • jcwatson60 Jul 07, 2008
    Doesn't power up. New battery and original battery both charge up fine. When an adapter is used (with battery installed or not installed), still doesn't power up. Tape is stuck inside the camera's compartment and will not come out. Is this a part of what JVC is having problems with? "Safe Mode"
I need the software and the driver for my video camera
Posted on Oct 06, 2008
Addapter connected but not charging for sharp VL-Z500
If not charging,3 reasons may be-
1.Charger is defective.Check adapter
2.Batt is defective.Try with another one
3.Camera is electrically dedective.Can't complete charging.
Oct 20, 2012 | Sharp VL-Z500H Mini DV Digital Camcorder
I am looking for a instruction manual for a sharp digital viewcam vl-nz50, do you know where I cam get one?
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Oct 30, 2010 | Sharp Viewcam VL-NZ50U Mini DV Digital...
I have a sharp 8mm camcorder. i have a tape that just plays the audio and not the video. HELP
there is differnt quailtitys in the 8mm tapes, i knwo there is a real HQ one that if its used int he standard 8mm cam corder you will only get audio from it. hope this helps in some way.
Nov 30, 2009 | Sharp Viewcam VL-AH151U Camcorder
The red light flashes when its charging
Had this problem myself and found that the voltage of the battery was too low for the camera to charge (2.8 volt,s)
I manually charged the battery up past 3 volt,s then put it back in the camera and plugged it in--the light did stop flashing and did finaly turn green.
Or just get an external charger online for cheep.
Oct 24, 2009 | Sharp Viewcam VL-AH50U Hi-8 Analog...
I cannot transfer video from my Sharp VL-NZ50 to my PC
I had the same problem with the VL-NZ50. It wasn't the camera, it was the IEEE 1394 interface on the laptop(s) -
I tried two different ones, one XP, the other W7 64; both were HPs with on-board (OHCI compliant) TI
IEEE-1394 chipsets.
Then I tried a Gateway desktop (Vista) with an on-board Ricoh
IEEE 1394 interface: the VL-NZ50 was recongnized instantly, controlled by the PC and transferring video flawlessly.
If you want it to work with your laptop , try an Adaptec PCMCIA card (I've heard they work with this camera), they can be had for under $10.
Jul 11, 2009 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Computer not reading my cam
u need to first install your software that came with your camera and then plugin your camera after restarting pc
Jun 25, 2009 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Sharp view cam vl a10
my view cam is blury when you try to play any movies on it.
May 31, 2008 | Sharp Viewcam VL-A10U Camcorder
No image during recording -- sharp mini dv VL-NZ50
This problem can certainly be fixed and is not that expensive : the no image in capture mode when you can playback is caused by faulty CCD sensor and you might even have it done free of charge because it is often a faulty sensor that goes in your camera during manufacture. Sony in particular repairs these faults free of charge, but others do too.
Sep 04, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
No image during replay -- sharp mini dv VL-NZ50
a cleaning cassette ( the red ' x ' ) will help : if cleaning works ? retire your old tapes , or your heads may need replacement - sooner rather than later ;
Apr 06, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Sharp Viewcam VL-NZ50U Mini DV Digital Camcorder Logo
537 people viewed this question
Top Sharp Video Cameras Experts
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
