Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
I have Kenmore 106.56676501 Side by side fridge. The freeze side is working greate. The fridge side does not have any cold air. I checked the air flow, I did not feel anything. When I defrosted, it works for couple of days then the problem came back. Please give me advise? Can I fixed it by myself? Thank You Thuyen
    Champion:
  • 363 Answers
If you can locate the circulating fan(evaporator) then i would replace it.
Posted on Aug 02, 2009
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
Kenmore 596 - temp control panel not responding when up or down buttons selected. Fridge too cold. Freezing items in fridge after power outage last night.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Okay, hope this will help in solving problem
Aug 07, 2011 | Kenmore 26.0 cu. ft. Side-By-Side...
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
Sears side by side freezer and refrigerator, refrigerator is too cold
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for the air deflector,As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
I think this will help in solving the problem... Take care......
Oct 31, 2010 | Kenmore Refrigerators
Everything in my refrigerator is freezing and my ice machine wont work
the cold control and the air deflector
Hope this helpout.....
Aug 11, 2010 | Kenmore 57029 Side by Side Refrigerator
I have a Kenmore Elite Side by Side about 6yrs old. It is working (fan is running, lights are on) just not producing chilled air. Any Thoughts?
Check that the condenser is not iced up and check that the air ducts are not iced up. Easiest way is to deforest the s/s entirely. If the Fridge is the problem and the freezer is OK then also check the electric shutter valve at the rear top of the fridge compartment on the side next to the freezer. This is where the cold air is sent into the fridge compartment by the cooling fan and air ducting. These do have a tendency to ice up and then breakdown so they stay shut and the Fridge keeps warm or they stay open and the fridge ices up and freezes the contents. Contrary to beliefe these types of FF are not totally frost free.
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Side by side freezer cold fridge not
the freezer may be overload or poor air circulation inside the freezer
Mar 10, 2009 | Kenmore Refrigerators
Fridge is not cold and freezer is not frozen
check to make sure the fan that blows cold air from the coils of freezer is working. If its not that could cause the freezer to be cool also.
Nov 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
226 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
