Question about Samsung Propel A767 Cell Phone
How can I enter a soft (2 sec.) pause in a contact number on A766
How can I enter a soft (2 sec.) pause in a Contact number keyboard remains set to 123.
    Problem Solver:
  • 16 Answers
1) From the Home screen, go to Start > Contacts
2) Select the desired phone number
3) Press the Menu soft key and select Edit.
4) Use the Left or Right navigation key to place the cursor at the place where the pause needs to be added.
5) Press the Menu soft key and select Insert Pause to add a two-second pause. The letter ‘p‘ will appear where the pause has been set.
6) Use the keypad to enter any additional numbers if desired.
Tip: You can create pauses longer than two seconds by entering multiple pauses.
Posted on Aug 02, 2009
How do I enter contacts and their phone numbers
Hi Joseph
Add a New Contact
Step 1 Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1 Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
Apr 18, 2016 | LG Cell Phones
Can i enter a mutiple number contact?
yes you can on most cell phones. try using pressing and holding the * key for a moment and it should put a comma(or a P) after the last # (this is a 1-2 second pause), then just key in the next numbers you want. (if you need more time between numbers, just insert more Pauses.)
i.e. 18005551212,1,12223334444
this would make it dial 18005551212 then wait 2 seconds,
then dial 1(to leave a callback number), wait 2 seconds,
then dial 12223334444 (your callback number).
some phones put a limit on how many numbers can be dialed with a contact...but you should be able to put most numbers in. i use this method myself.
Mar 24, 2014 | Blu Zoey T176 Mobile Phone
Needs to reprogram fax machine, has old fax numbers in
1. Press Menu/Set, 2, 3, 1.
2. Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3. Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter a pause in the dialing sequence (for example, to wait for an "outside line"), press Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing Redial/Pause enters a 3.5 second pause when the number is dialed.
4. Use the dial pad to then enter the name (up to 15 characters), and then press Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name, press Menu/Set.
5. Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or, if you haven't stored a name, the number you've stored.
If you loose electrical power, auto dial numbers in memory will not be lost.
(For USA Only) One-Touch key 1 has been pre-programmed for the Brother faxback system. One-Touch key 2 has been pre-programmed for the CallManage long distance plan. You can override them if you wish.
Note If you need to store a pause longer than 3.5 seconds, press Redial/Pause two or more times.
Note - You can store Groups (for Broadcasting) on the One Touch keys.
Dec 11, 2010 | Brother IntelliFax-2820 Laser Fax
We lost our manual and I am trying to reload our speed dial numbers. I have tried everything but can't seem to figure it out. Help?
1 Press Menu/Set, 2, 3, 1.
2 Press the One Touch key where you want to store a number.
3 Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter
4 Use the dial pad to then enter the name (up to 15 characters), and then press
press Menu/Set.
5 Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
Dec 07, 2010 | Brother IntelliFax-2820 Laser Fax
When I try to save a contact on my palm pixi it just says "error." I can't save new contacts, I can only add to existing. How do I fix this?
You can add a contact that synchronizes one of your online accounts, such as Google or Exchange. You can also add a
contact in the Palm Profile account, which does not synchronize with an online account but is backed up daily to your Palm Profile.
If you are using Contacts for the first time, you go through a few different steps to get or access the contacts on your phone (see Using Contacts for the first time ). Follow this procedure to add contacts directly on your phone after the first time you use Contacts.
1. Open Contacts .
2. Tap .
3. (Optional) Tap the account button to the right of Name to change the account to which the new contact will be added.
4. Tap fields to enter contact details, select a ringtone for that contact, add notes, or add birthday details for the contact. Scroll to see all of the fields available for contact info.
5. In some fields, such as New Phone Number, when you enter the information a label button appears on the right. Tap the button to change the label for your entry-for example, to identify a number as a mobile or work phone.
Tip Use the Reminder field to enter that important message or question you have for this contact. The next time you send or receive a call or a message to or from the contact on your phone, the reminder pops up on the screen. You can also add a reminder later (see Assigning a reminder message to a contact).
Tip To insert a two-second pause in the dialing sequence, enter a T where you want the pause to appear. To insert a stop in the dialing sequence, enter a P where you want the stop to appear; to dial the next set of numbers after the stop, tap the screen.
6. Tap Done.
Oct 24, 2010 | Palm Pixi Cell Phone
I have a Nortel 7316. I have tried an incorrect password one two many times and now it is "locked" and says "contact administrator". Boss has no idea how to gain access. Help?
To reset your voice mail password,on press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Oct 15, 2010 | Nortel T7316E 2-Line Corded Phone
Dialing speedial 1 does not access my voiemail even tho it says it is dialing it a greeting comes on asking for an access code. the nly way to get voicemail is dialing manually and the icon onscreen does...
OK, usually one cannot use the speed dial feature unless you insert, pauses in the number, IE: you must add 1 second, "Pauses", after and before the number you dial... also you can then add, your access code too, well theoretically anyway..
So, you pause, for 1 sec, then dial the number, pause for 2 - 3, 4, maybe 5 seconds, seconds, then enter your access code and Enter code.
This should then be able you to then speed dial and connect and enter your PIN, all at the same time, if your PIN isn't recognized, try adding more pauses before entering.
If NONE of it works, then you simply have a network/phone that will not do it.
Aug 11, 2010 | Cell Phones
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
I want to program a new number into my old A900 Samsung phone to replace my wife's old phone.
Hi
Surprsingly u never mentioned the name of the network which u r using. Please mention the CDMA server's name.
Thanks.
Supriyo DG
Jun 19, 2008 | Cell Phones
I need to remove a # from the rejection list
go to - menu-> settings-> application settings->  call->  all calls->  auto reject-> (scroll one down) reject list->
[on the reject list uncheck number you wish to remove from the reject list. ]
-this is the most accurate answer, trust me.
Jun 18, 2008 | Samsung Cell Phones
Samsung Propel A767 Cell Phone Logo
393 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
