Question about Kenmore 15892 Built-in Dishwasher
Clean light flashing won't start new load
I am having the same problem. clean light flashes 7 times and repeats itself. won't start a new load
  • 5,911 Answers
This may or may not help in your situation, but the following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this fixes your problem.
Posted on Aug 02, 2009
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
My dishwasher isn't working. The clean button
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats this occurs when the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Why doesn't paper feed after "print" instruction? Printer merely makes a mechanical noise and states "paper out" condition.
Hello.
There are lots of reasons why this would happen:
Foreign object (could be very tiny)
Any power lights flashing ?
Paper feed rollers may need cleaning - try (from Canon Support):
1. Ensure that the printer is turned on. If any paper is loaded in the printer, remove it.
2. Select which roller to clean, the auto sheet feeder's or cassette's, by pressing the <Paper Feed> switch on the printer.
3. Hold down the <Resume/Cancel> button; when the Power lamp flashes green three times, release the button. The paper feed roller will rotate as it cleans itself.
4.. Repeat step 3 twice.
5. Load three or more of A4 or letter sized plain paper in the auto sheet feeder or cassette, as selected in step 2.
6. Repeat step 3. The paper that is loaded in the printer will be fed through the printer and ejected.
7. If printing problems persist, repeat step 6 up to three times.
Could be a hardware error and the printer would need servicing - still under warranty ?? If so, return to Canon for repair or replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Bllinking "clean" and cant start a new load? Need to reset? How to reset?
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 08, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Clean light flashes 7 times then repeats
Bonjour,
ma machine à laver la vaisselle., Maytag, le modèle S-MDB9600AWS PLASTIQUE éclaté sur les deux roues tiroirs connectés navires. Où puis-je acheter ces roues et ce que nombre d'entre elles ont?
Merci,
Aug 17, 2009 | Kenmore Dishwashers
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Clean light flashes
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Jan 09, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 15892 Built-in Dishwasher Logo
232 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
