Question about AudioBahn A2300HCT Car Audio Amplifier
Protect light stays on
My audiobahn 2300 hct amplifer stays on protect now. i have it running to an 18 inch kicker solo x. even when i un hook the 18 from the amp its still on protect. ive taken the amp apart and nothing appears to be blown..amp doesnt smell burned and theres no black burn marks either around the channels and ground...what could be my prob;em? it use to work just fine
  • Scoupe May 03, 2008
    I have this same problem... and the protection light keeps staying on.... I took it to a guy to repair and he said all the components are in working condition... hmmm but it was working good and just recently the protection light came on... i disconnect the speakers... and run the amp by it self and still stays on... if there is any help to this... i would appreciate it thanks....
  • 100percent May 28, 2008
    when i took the amp out of my car it was working find but when i put it back in the protection light came on and stays on now
    Problem Solver:
Same amp same problem. HELP!!!!!!!!
Posted on Sep 02, 2008
  • 631 Answers
It's likely that the output transistors have failed. If you measure the resistance between the second and third legs of the large transistors adjacent to the large (green?) resistors, you'll find several that read ~0 ohms. Its likely that only one of several that read 0 ohms is defective but all that read 0 ohms in the board are operating in parallel and must be replaced together so they match (electrically).
Disconnect the amp from the power source BEFORE trying to measure the resistance across the resistors.
Posted on Nov 25, 2007
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Audiobahn a8002t amplifier in protection mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. audiobahn-a8002t-amplifier-in-protection-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
Dec 21, 2009 | AudioBahn A8002T Car Audio Amplifier
Amp goes into protection
make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Protection light lights up for a second and turns off and the amp seems like it is not working. It is connected and wired correctly.
disconnect the speakers from the amplifer, and turn the system on again. if the protection light still is active even without the speakers hooked to it, then it is most likely that you have a blown transistor in either the power supply section, or the output section.
Either way, your amplifier will need to be serviced.
Dec 07, 2008 | Kicker Car Audio & Video
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
Audiobahn 2300 hct schematic
help with what? Finding the schematic? Interpreting it? Troubleshooting?
Sep 02, 2008 | Car Audio & Video
Audiobahn A2300-HCT
bring it to a hifi or tv repairstore
Nov 04, 2006 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A2300HCT Car Audio Amplifier Logo
137 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
