Question about Epson Perfection 1660 Photo Flatbed Scanner
At power-on scanner makes clonk-clonk-clonk- noise
  • trimwells Sep 04, 2009
    You are so right!
    Actually, Epson NZ was able to help me quite quickly. They said:
    'At the back of the scanner is a sliding tab that is used to lock the scanner for transportation'. [Somehow this tab had been moved to the lock position, probably when rearranging things on my desk!]
  • 58 Answers
The clunking is the belt jthat moves the light is jumping the sprocket gear.
Solution - Unlock the scanner. About 1 inch below the right lid hinge near the USB jack is a fimmed piece of plastic. Slide this left or right to Lock/Unlock the scanner.
Posted on Sep 04, 2009
Testimonial: "Yes, you are so right!!! [Epson NZ gave me a similar response when I phoned them!]"
  • oloo Sep 04, 2009
    Thanks for the comment :)
    Sorry about the spelling, I forgot to proof read my solution.
    It should read : The clunking is made by the belt that moves the light, jumping the sprocket gear.
    Solution
    USB jack is a finned piece of plastic. Slide this left or right to
My 12 yrs old house has now got excessive clonking noise coming from the internal pipe system-seems to occur every 20 mins or so-even I believe caused the fracturing of the backing plate where clamp...
Normally clonking noises are caused by loose pipework.
As the valve closes the inertia in the water bangs the pipe against the wall.
For instance in heater radiator systems it can also cause a continuous banning noise when water under pressure is pumped through it, usually in sync with the rotation of the pump motor.
Mar 13, 2015 | Home
At start up,engine makes clonk noise ,second it starts,
The clunking is most likely the starter/flywheel issue. Loose starter, starter or started bendix damaged or flywheel cracked. The P0137 is a post O2 sensor voltage low. If the sensor has not been changed, probably the sensor has failed.
Apr 05, 2014 | 1999 Chevrolet Silverado 1500
Loud clonking when on spin only when filled with clothes
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 14, 2011 | Indesit WA 125 Front Load Washer
The refrigerator make a clonking noise intermittently, It seem to be at the end of a compressor cycle. I am not sure of the time between the cycles, but I started noticing the noise recently and it seems...
this must be a older unit . and what you can hear is the compresor comming to rest . the clonking noise is the mounts inside the seald unit . have or are failiing . due to age . best solution is to run it till it won't . it may take years before it won't go . hope this hepled mm .
Oct 16, 2010 | Refrigerators
Thread's bunch-up lower fabric
Make sure your bobbin is in proper and secure, it should click when you put it in. Also try putting a new needle in. Clanking noises are sometimes a bent needle.
Jul 16, 2009 | Singer 3116 Simple
Front End Noise
Sounds like a bad motor mount.
Sep 11, 2008 | 1997 Ford Escort
Epson Perfection 1660 Photo Flatbed Scanner Logo
213 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
