Question about Toro Lawn Mower With Toro Power Tools
My toro mower wont start
My husband drained the gas and let it dry out new sp new filter
  • 77 Answers
Put a spark tester on the plug to see if it is getting spark,could be bad coil,if thats good,probably needs carb rebuilt.
Posted on Aug 10, 2009
Toro personal pace mower not starting
First check the gas. Old gas after only 3 or 4 months of storage will not fire properly. Completely drain the tank and add some fresh gas. Also take the air cleaner off and check the air filter. It is possible you may have tipped the mower to that side while hosing the grass from the underside. The filter could now be plugged with oil and the motor can not breath. Replace the filter if this is the case. And finally, replace the gasket on the back side of the air cleaner plastic housing that attaches to the carburetor. This gasket if defective or dried out can prevent the primer bulb from injecting gas into the carb when you pump it. Its also possible it fell off if you ever removed this cover which is bolted on with 2 screws. Some dealers even go as far as to put 2 gaskets on to get a good prime. If these simple fixes don't work. You also could have sheared the key way when the motor hit something you ran over in your yard. That will require a shop to pull the flywheel and gets a little more involved.
Jun 03, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Mower wont start changed plug still wont start checked gas line seemed okay but what is that plastic piece in the line never seen one before
Getting a mower out of its winter slumber takes some time. Start with fresh gas, new oil, and air filter. Sometimes carbs get gummed up(varnisized gas). Donyboy73 on youtube shows how to remove Briggs n Stratton in tank carb systems and clean the parts and passages.
Apr 27, 2013 | Toro Power Lawn Mower
Toro ride on wont start
Battery required? Charge battery or replace. Replace air filter and spark plug. Dump out old oil and replace with 30w oil. Electric start may have a fuse blown. Dump out old gas fill with new with Stabile always added to gas. Try spraying starter spray in carb at air cleaner with filter removed. All mowers have a low oil sensor to prevent starting on low oil. Remove bowl from carb, should be full of gas. Pinch off fuel line with pliers or turn fuel valve off. Check float should be hanging down allowing fuel flow. Float up stops fuel flow.
Sep 19, 2012 | Toro Power Lawn Mower
Toro model 20331
I have a toro mower and it has same problem,my husband replaced some parts&it worked but then started same thing again,he hasn't had time to mess with it again seeings hes been working reg. job&every other spare minute been spent trying to fix our truck! Id love to see an answer for mower to help this person&us also!!
Aug 17, 2012 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Wont run smooth
have the govenor checked could be the spring is worn down
May 10, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 2 stroke lawn mower won't start
Remove the Carb Bowl and on the bottom of the bowl clean the center of crust gas....
It blocks the gas from getting from the bowl to the inside of the carb.
Caused when gas dry's up in the bowl leaving deposits behind plugging up the works.
AL
Apr 26, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
238 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
