Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Printer is printing jibberish on not working on test prints
I need 6 pc's to share this printer everytime i try to print with the first pc it just prints jibberish until i cancel the print. do i need a default ip? Can i set it up another way? do i need to assign it a new ip? HELP!
  • 95 Answers
If you can print to it the network setup is ok. It sounds more like a print driver problem.
Posted on Aug 02, 2009
An updated set of drivers was available. thanks
Posted on Aug 11, 2009
HP LaserJet P3005 Printer will not print using a parallel cable.
# Switch off the printer, cancel pending jobs..Refix parallel cable both ends & tighten them Check proper drivers installed or not if not install proper drivers.. shoot print command. check..if not resolved...For tech guys:# Replace cable..checkRemove printer formatter, check any dry solder or pin breakage at parallel port.(show in snap shot), found... try to repair it or replace the formatter assm. Check system parallel port working or not...
Dec 30, 2011 | HP LaserJet P3005 Printer
725 printer prints constanty on its own when not called for
If it's printing jibberish or "ASCII Garbage" then you probably have the wrong print driver installed.
Uninstall the print driver, disconnect the printer, reboot and reinstall the driver plugging the printer back into the PC when the installation software prompts you to.
Mar 12, 2011 | Dell 725 InkJet Printer
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
Printing jibberish!
Delete the printer icon. Restart your PC. Reinstall the printer driver. If that doesn't work, your printer cable may be faulty.
Jun 28, 2009 | HP PhotoSmart C4280 Laser Printer
Prints, but jibberish
This souds like a printer driver problem.
Go to Strat ,Control Panel and then printers.
Delete the current printer ,reboot and windows will reinstall it.
Try printing again
Jun 09, 2009 | HP DeskJet 932c InkJet Printer
Every time we try to print it just says error and won't print
If this printer was working fine before, it probably just needs to be cleaned really good with clean compressed air that has no moisture. Also do a test print after you blow it out. If it prints fine in test print then you know that your problem is not in the printer and you may need to reinstall your printer software driver. Check it out. God bless you.
Jan 12, 2009 | Epson LQ-570e Matrix Printer
My shared printer will only print a test page and nothing else!
Hi phall124
Have you made the new connected printer on 2 other PC's the default printer. Try selecting the printer in word by not just clicking on printer icon but using the following:
1.File
2.Print
3.Select printer from drop down box
4.Print
Regards
Go-Tech
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Sharp 1642CS shared printer
You can go into your print driver and change the Driver. I dont think there is a difference between Home or Prem drivers. There is how ever a difference between 32 bit and 64 bit Vista?
When you set up the printer and share it from a PC, The printer attached to that PC can Control the Configurartion of the printer. PC's can either pull the driver from the sharing PC or you can select your own.
I would first check that the correct drivers are installed, (64bit or 32bit)
I would check the computer that is trying to print. replace the driver with the correct one.
You can open the print server -open the printers and fax folder, right click in a white area in that folder, a menu should pop up. Select Print Server from there you will see tabs, try to replace the driver from there.
Or Open the Printer Properties and there you will see Driver-Update in there.
This is a link to an explanation
Thou it was made for XP but the basic Infomation is the same.
-->Print a test page from The Printer Properties), if it works the Computer is fine, if you try to print from a program and it prints with errors. it is in the program..
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
Nov 05, 2008 | Sharp AL-1642CS Copier
Test Page automatically prints
Disconnect Printer from PC. Uninstall the driver and download most recent driver from HP web site. If there is a print management program which there should be uninstall this as well and download the latest version.
Shut down, not reboot PC
Start PC
Start the install process by installing the print management program installation. Follow the process and test. If it persists try a different USB cable.
Karl
Oct 31, 2008 | HP PSC 1315 All-In-One InkJet Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
190 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
