Question about Kenmore HE2 Plus Front Load Washer
Wont agetate kenmore 30washer
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Maytag performa PAVT234AWW top load washer. The washer fills and spins fine. But when it is the wash cycle, the agitator makes a grinding noise and kind of vibrates in place. Is this something that can...
sounds to me like you have a bad transmission
what happens when you take the agetator off
does it still make the noise or does it go away?
if it goes away when you take the agetator off then you have a bad agetator
Aug 24, 2010 | Maytag Washing Machines
There is a banging during spin cycle and clothes come out soggy-wet. Checked the coupler already, looked fine. Please help??
take the adetator off. and check the shaft of the transmission. possibly your drive block and basket drive are stripped. if it's just your drive block no prob but if it's both major surgury.
get a putty knife and take the cap off
under lid of agetator you will either find a 7/16 bolt or you will find a 1/4 inch drive socket
either way remove
then the agetator will slip right off.
next if you have them remove the 2 peices on the shaft you will see the drive block and the 2 ears of the basket drive.
turn the basket with your hand
what happens does it make the sound?
let me know if this helps or if you need more help?
Apr 05, 2010 | Kenmore 22422 Top Load Washer
Lower half of my Knmore Washer does not agitate
do you mean the top does not agetate but the bottom does?
replace your agetator dogs
part number 80040
you need to take the agetator off nad seperate the bottom from the top you will see your agetator dogs.
Feb 15, 2010 | Kenmore 24032\24036 Top Load Washer
Sears 700 series top load washer, model 110.27711600
no that is a shipping pin when they pulled the strap those pins fall into those little cups instead of onto the floor. so it does not spin. does it agetate? if the answer is yes you probaly have a good drive coupler. Possible suspects would be a bad transmission if it is stuck in nuetral drain, clutch if you can push start the basket in spin cycle you have a bad clutch, bad drive block you need to take the agetator off and check to see if the drive block is not raised from the basket drive basket drive has 2 ears that fit into the drive block.
Jul 24, 2009 | Kenmore 24032\24036 Top Load Washer
Agitation issue
So you say the agetator is moveing or when the clothes go up and down does it stay in place and make a rattcheting sound. if it is not moving the clothes up and down you need new agetator dogs. pop the cap off the top of the agetator some have a plastic cap that you can poull off to get to the 1/2 inch screw inside. some don't if you can see the bolt around the edges of the inside of the agetator you will see groove marks and when you turn the agetator by have you will see 4 plastic tear drop looking thing that grab the grooves of the agetator these tear drop things get stripped over time. replace them and this should solve your problem. let me know if you have any more questions
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Flipped Kenmore over to replace pump now oil leaked out, where?
did you tip the washer all the way over? bad idea if you did. is the washer functioning ok? if so don't worry about it. but no....you cannot put the oil back in. It might be ok as long as it does not leak any more oil. This oil is comeing from your transmission. which controls your agetation and spin.
Mar 26, 2009 | Kenmore 22642 Top Load Washer
ON SPIN CYCLE AGITATOR MAKE A LOUD BANGING SOUND
So while you are holding the agetator is it ripping your hands? or is the agetator just sitting there? If the agetator is just sitting there you probably have bad agetator dogs. I would remove the fabric softner or cap whichever you have. under the cap you will see grooves in the agetator down low. When you manually turn the agetator you should see 4 tear drops that grab the grooves if you do not see this you have bad dogs. Very simple. This usually is the cause for the grinding noise that you are hearing. Please let me know if this works for you //eg
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
90 series washer doesen't adgitate on the first wash cycle
usually this would be caused from stripped agetater dogs. take the fabric dispener off if you have one. if not take the cap off with a putty knife you will se a cap pull it off. there are 4 tear drop looking thing that is what makes the washer agetate. they grab the grooves of the agetator and turn it. if they are stripped they need to be replaced
Jan 04, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer mode
thas exactly correctits amotor coupling part number 285753A, probalby $25 and you can find complete tear down of unt on you tube
Dec 08, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
