Question about Acer Computers & Internet
Computer beep every 10 sec one beep no screen but have power
    Novelist:
  • 129 Answers
Hello.
Once when you turn your computer on and it is beepin this is a memory problem. Are you famillair to open the CPU casing you need to check the memory stick. Clean the dust in memory stick and the slot try to use the another slot. If the same things happpen and you have extra memory stick try to use it.
Thank For useing Fixya.
ICmanServer
Posted on Aug 02, 2009
Power button
You need to count the beeps then go to google search for beeping codes then you will see the codes. Repost them herell
Terry
Mar 31, 2014 | Acer Aspire Z5600 Z5610 Z5700 Z5710...
I installed Dell Vostro 1000 System BIOS, v.2.6.1, A04 on myDell Vostro 1000. When it was finished the screen went black and it won't start. Now what? is the computer ruined?
Yep I did the same. Finally recovered using the link shown below.
http://hotfile.com/dl/113520903/05689ed/VOSTRO1000_CRISDISK.ZIP.html
To Create a Crisis Recovery USB you must use a Win XP system
Note: Running XP through compatibility more in Win 7 will not work
1. Insert Blank USB Drive
2. Open "CRISDISK" folder
3. Open "WINCRIS" application
4. It should detect the USB Drive
5. Click "Start" Button
WINCRIS should create the USB recovery drive
6. For Crisis recover, be sure to Power drain system.
A. Remove Battery
B. Depress power button for 10-15 sec.
7. Insert USB drive into USB port.
8. Hold END button while plugging in power cord in system
9. Continue to hold END and depress and release the system power button.
10. Continue holding END until USB drive begins to flash and a beep is heard.
11. System may remain blank as it enters recovery mode - Anoying Beeping will be heard - Beeping will stop and FANS will function Another series of Beeps will be heard
12. System should complete recovery in 5-10 min. If system has not powered down in 15 min, power down by pressing the power button
Good luck Dean/Steve
Mar 11, 2011 | Computers & Internet
HP A6600f desktop, loud beep 18 secs off 10 sec, cylce repeats
The beep is a code to tell you what is wrong. POST - Power on Self Test. http://en.wikipedia.org/wiki/Power-on_self-test You can serach the web for more detail as well. Usually memory has popped loose or a connection is not seated fully.
Apr 24, 2010 | Computers & Internet
Consecutive beeps last 10 seconds, silence for 5 seconds, the long beep for 10 seconds...pattern repeats. Nothing comes on screen. I removed single RAM card, tried other slot, same problem. I powered it on...
how many beeps any breaks between beeps and then how many like 3 beeps then stops for 1 sec then beep beep beep stop beep beep beep check to make sure that your installing your memory sticks right and they are seated all the way make sure all cards are seated right all wires are not shorting out and a worst case your cpu is good
Dec 25, 2009 | Biostar K8VGA-M Motherboard
Can't start up computer
The siren sound is a alert sound that your processor is overheated. please check the processor heat sync and fan installed properly?
Apr 18, 2009 | Abit KN9 Motherboard
Older Gateway e3200 powers on but the screen does not turn on
.. Your board may need flashing..
Remove the side panel.
unplug the system
remove the battery from the main board, pry it loose,
remove memory (rams)
press the power button and hold it for 10 sec
replace battery and rams, plug in and turn on!
if you hear nultiple beeps the memory is damaged and needs replacing
if you hear beeps and slow intervals or none at all processor is damaged
other than that it should boot.
ps. Enter settings or bios and load defaults or optimal then save and exit. ... > after flashing.
Apr 03, 2009 | Computers & Internet
Playstation 3 HDMI
with redlight on...hold power button for 10-15 secs to reset the HAL registers (HDMI) should beep once..then 5 secs later once again
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
I have a Canon BJC-80 and when I turn it on it goes through the on process, but then the error lighs up and beeps then the green power light just flashes green. What do I do?
well..disconnect from computer first
turn off power
unplug from wall(it's installed in wall, right?)
press power on button down, after 30 sec of off time
plug it back in with power button held for 10 sec
see if that helps a bit
Aug 19, 2008 | Office Equipment & Supplies
Screen blank, nor hard drives activities and cpu activity neither
Are you getting any beep codes? If so, please list what type (number of beeps, long or short beeps, or combo of).
May 24, 2008 | ASUS A7V8X Motherboard
Alarms
Hello, find the BIOS Beep Codes at http://www.amptron.com/html/bios.beepcodes.html and try to find your problem. It is not a software or Monitor problem. It could be RAM or Video Card failure
Aug 04, 2007 | Biostar M7VIZ Motherboard
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
